backflip/apndroid.....help with settings, etc...
This is a discussion on backflip/apndroid.....help with settings, etc... within the Motorola Backflip forums, part of the Motorola Android Phones category; this has probably been asked a million times, and searched around, but figured i'd post neways since i am still having a problem. just got ...
Thread: backflip/apndroid.....help with settings, etc...
    Junior Member dakotadogg's Avatar
    just got a backflip and do not want to use the at&t data at all.
    the only reason i need the att for data is mms and sms. i'll use the built in wifi for everything else..
    i downloaded the APNDROID program installed it and have the current settings:
    3g/edge/gprs (status light is grayed out)
    MMS (checked)
    Notifications (checked)
    Diable all APNs (unchecked).
    i can't get MMS to work on the phone.
    am i missing something here ? i can send and recv text messages, but it's the data that is giving me problems...
    thanks
    If im not mistaken inorder to recieve and send MMS you have to have the data feature turned on and installing a third party application that disables Data will not allow you to use MMS. I could be wrong but I think that is how it works. SMS can be sent with no data plan but MMS uses data.
    Senior Member jmgib's Avatar
    Kentucky
    The MMS checkbox is supposed to allow you to still receive MMS messagse with the data turned off. I'm not sure the method they use to accomplish this or how well it works. I'm guessing this is one of those "experimental" settings which may or may not work reliably. You can also try using Quick Settings which I believe has a similar option. YMMV.
    that's what i thought with the MMS check option. but no go. i guess it's ok. i have it turned off right now and texting still works fine.
    for me to flip a switch to get a mms, i guess it's not that bad..
apn setting/etc.com
apn settings motorola backflip
at&t motorola blurr apn setting
att apn settings for motorolla blur
backflip apn att settings#gsc.tab
downlad net10 apn for motorola backflip
lime apn settings for motorola backflip
motorola backflip apn
motorola backflip apn settings
motorola backflip net10 apn settings
net10 apn setting for motorola backflip
net10 apn setting for motorola backflip at&t
net10 apn settings
net10apn settings for motorolla blur
