Data plan is required for this phone?
This is a discussion on Data plan is required for this phone? within the Motorola Backflip forums, part of the Motorola Android Phones category; hello everyone, i just received my backflip two days ago. it is charming. but i have a question here. When i ordered it together with ...
Thread: Data plan is required for this phone?
    Junior Member lxacer's Avatar
    hello everyone, i just received my backflip two days ago. it is charming. but i have a question here. When i ordered it together with one iphone online two weeks ago, it is not requiring me to choose data plan for this phone because it is a refurbished one. But when i received it and turned it on at the second day after i received it, it was automatically active and used 3G data. I talked with att representative, he told me the system identified backflip as a smart phone which is obvious and automatically added data plan to it. Thus i cannot get ride of it. so what is going on? why it is not requiring data plan when i ordered it online and why now? i am confused. anybody can explain it? i will appreciate it very much.
    Senior Member jmgib's Avatar
    Kentucky
    ATT requires a dataplan for all smartphones. Not sure how you were able to order it online (did you order it directly from ATT or from a reseller?) but as the rep explained, once you activated the phone, a dataplan was automatically added to your account.
    Yes, you are right. i just went to the local store and asked again. some thing.
    i ordered this through ATT website. i do not why. but it is true. when i bought this phone, i can skip the data plan option and in the final monthly bill there is no data plan added.
at&t motorola backflip need data plan
do you need a data plan for motorola backflip
do you need data plan with android backflip
does a motorola backflip require a data plan
does backflip require a data plan
does motorola backflip need data plan
does motorola backflip require data plan
does the motorola backflip require a data plan
does the motorola razr v3 require a data plan from att??
motorola backflip att data plan required
motorola backflip data
motorola backflip data plan required
motorola backflip does it require data plan
motorola+backflip+data+plan required
what data plan is needed for motorola backflip
