any way to keep it from locking or screen timeout in call
This is a discussion on any way to keep it from locking or screen timeout in call within the Motorola Backflip forums, part of the Motorola Android Phones category; this has been an annoyance, the screen will lock or go into timeout when I am in a call and need to press buttons....
Thread: any way to keep it from locking or screen timeout in call
    Member sgtarky's Avatar
    Senior Member jmgib's Avatar
    Kentucky
    There is a proximity sensor in the phone that turns the screen off when it detects the phone is close to your face/head to keep you from accidentally hitting buttons. It should turn the screen back on if you take the phone away.
    If you're talking about the normal screen timeout, that can be changed under the display settings.
    mine never turns back on when I remove it from my face, i found when I have to make calls that require dial trees, I just leave it on speaker.
    Junior Member oregoner's Avatar
    Try Keepscreen
    I used keepscreen to keep the dialer screen open for when I need to press keys. It stops the timeout but not the blank screen when you put the phone to your ear. Solves part of the problem
    Senior Member Con5150's Avatar
    Bronx NY
    Quote Originally Posted by sgtarky View Post
    I do this too, figured it out after a few calls that required me to press numbers were messed up 'cos of that issue. It is very annoying.
    Sent from my MB300 using Tapatalk
  1. New Update
    Last Post: 12-24-2010, 02:38 AM
  2. Updates?
    Last Post: 11-05-2010, 07:06 AM
  3. Panoramic feature
    Last Post: 08-28-2010, 12:15 AM
any way to keep my android from locking?
