j_r0dd's 2.1 beta help
This is a discussion on j_r0dd's 2.1 beta help within the Motorola Backflip forums, part of the Motorola Android Phones category; To run ADB go to Start->Run->CMD(in the box) and then a black screen comes up. You need to type CD C:\android where android is the ...
Results 11 to 14 of 14
Thread: j_r0dd's 2.1 beta help
    To run ADB go to Start->Run->CMD(in the box) and then a black screen comes up. You need to type CD C:\android where android is the folder where the SDK is installed. THEN run adb shell.
    Member kschumake83's Avatar
    the way i do it is i go into the sys32 file and copy the cmd program and paste it into my sdk/tools folder so it always just comes up for me i dont have to tell it where to look
    Member Casual-T's Avatar
    Welp, I went ahead and moved on to the actual ROM installation and, so far it seems to work! 2.1 is pretty awesome! I guess I got a bit over-worried with the command results. Thanks anyway for the help!
    Senior Member jmgib's Avatar
    Kentucky
    Quote Originally Posted by kschumake83 View Post
    You could have just added the path to the SDK to your PATH and not actually copied the file to your system32 folder.
    System Properties-> Advanced-> Environment Variables // Select PATH and "EDIT". Then just paste the path to the folder at the end, making sure it is separated by a semi-colon ';'
  1. T-Mobile announces Dell Streak 7, it's first 4G Tablet
    By JohnDroid in forum Android News
    Last Post: 01-06-2011, 02:22 PM
  2. Android 2.2 iPad Alternatives
    By TMODroids User in forum Off-Topic Forum
    Last Post: 12-07-2010, 02:12 AM
j r0dd's 2.1
j rodd mb300
j rodd recovery 2.1
j rodd-mb300-v1.8
j rodds recovery
j'rodd 2.1 recovery download
j-rplodd-mb300-v1.8
mb300 recovery 2.0
motorola backflip j r0ds recovery 2.0 download
motorola backflip j r0ds recovery rom download
pdanet download
