LED flash??
This is a discussion on LED flash?? within the Motorola Backflip forums, part of the Motorola Android Phones category; my guess would be he's referencing the fact you could change the code in the rom for the proximity sensor....
Results 11 to 13 of 13
Thread: LED flash??
    Senior Member wdeydwondrer's Avatar
    Louisiana
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    To change the polling frequency of the proximity sensor to where it updates whether or not to deactivate/reactivate the touch panel/screen... do this...
    Make sure adb debugging is enabled. This requires root AFAIK.
    "adb devices" <-- To make sure ADB recognizes your phone from the prompt.
    "adb shell"
    "setprop mot.proximity.delay <value>" <--- in place of "value" put a number greater than 1. I would say 3 or 4.
    "getprop mot.proximity.delay" <-- that will tell you what the current value is, if the above is accepted.
    **You may have to reboot the phone for this to take effect.
    Thanks, I only tested it once but it seemed much more responsive. I set it on 3 for now.
does the motorola backflip blink led stop working
flashing green light motus mb300
mot.proximity.delay#gsc.tab
motorola android phone flashing led
motorola led falsh
motorola led flash
what does led flash on an android camera phone mean
