problem after 2.1 on backflip
This is a discussion on problem after 2.1 on backflip within the Motorola Backflip forums, part of the Motorola Android Phones category; Originally Posted by pdg mmmm what is IDK? I don't know. Lol...
Results 11 to 19 of 19
Thread: problem after 2.1 on backflip
    Member dtowngangsta's Avatar
    Flint, MI
    Quote Originally Posted by pdg View Post
    mmmm what is IDK?
    I don't know. Lol
    [\Marvin the Martian/]:blur:
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    mmmm what is IDK?
    I tried already to flash the OEM firmware "att-motus-endive-3.0.1390-secure-production-supermonster-customer.sbf" with RSD lite.
    If after doing that, you still have keyboard problems... The only thing I can think of would be hardware issues. Flashing the SBF flashes everything back to stock, including the radio.img, recovery.img, and the android system files.
    Junior Member pdg's Avatar
    it is like the recovery partition disappears when I have this problem, because if I try to start phone in recovery mode (power+camera>down volume) I get a blue screen (security on, fastboot disabled) and I can't get the recovery
    Senior Member jmgib's Avatar
    Kentucky
    Did the problem start though before you rooted your phone?
    no, the problem started after I upgrated to 2.1.............. I rooted phone only after the problem starts
    Kentucky
    I suppose it is possible that you had a bad upgrade or the download was corrupted, but I don't believe I have seen anyone else reporting the issue you have, where the recovery partition was corrupted after the official upgrade from Android 1.5 to 2.1.
    One thing you can try to do, since you say reflashing a recovery image resolves it, if you put the recovery image in /system/recovery.img the phone will reflash that image on boot, so this may be a workaround for you.
    If you rename j_r0dd's recovery or whichever image you are using to just "recovery.img" you can do the following to do this.
    From a command prompt on your PC with adb setup
    Code:
    CD TO WHEREVER THE recovery.img IS LOCATED
    adb push recovery.img /system/recovery.img
    Flint, MI
    Why don't you just try downloading ROM MANAGER from the market and using that clockwork mod recovery to do what you have to do. It has almost all of the features that j_r0dd's has. I am using it with my Preclair v.1.2.1 now.
    ohh sorry, what does ROM MANAGER do exactly? have I to use it with root?
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    Yes, you have to have root to use ROM Manager.
att-motus-endive-3.0.1390-secure-production-supermonster-customer.sb una version similar
can you install american stock oem on british motorola mb300
flash por rsd motorola backflip
having problems rooting my backflip 2.1
how to install firmware motorola mb300 rsd lite
mb300 after install azerty patch
mb300 security on fastboot disabled
moto backflip keyboard problems
motorola backflip sbf
motorola backflip security on fastboot disabled
motorola mb300 fastboot
motorola mb300 security on fastboot disabled
root backflip recovery flasher clockworkmod recovery security on, fastboot disabled
security on fastboot disabled mb300
