problem after 2.1 on backflip
This is a discussion on problem after 2.1 on backflip within the Motorola Backflip forums, part of the Motorola Android Phones category; hi, I installed android 2.1 on my motorola backflip, all is good but sometime I have a problem with the keyboard because some keys don't ...
Results 1 to 10 of 19
Thread: problem after 2.1 on backflip
    Junior Member pdg's Avatar
    hi, I installed android 2.1 on my motorola backflip, all is good but sometime I have a problem with the keyboard because some keys don't work in correct way (example, when I push "w" I get a "s", when I push "a" I get "ia",.....). I saw that when I have this problem I can't use the recovery mode because I get a blue screen with the text "secrity on, fastboot disabled". so I have to re-install the recovery o replace the installation of android and all return perfect, but the problem returns again after some time. I tried also to root the phone and install the j_r0dd-mb300-v1.7.6.1 FINAL [Recovery] following the thread on modmymobile.com but after some time the recovery mode disappears and I get the same problem. I tried also to flash android with rsd lite, but same problem. so I think the issue is related with the recovery partition.
    any help is appreciated, thanks for reply.
    ps. sorry my bad english!!
    up!!!
    please, any solutions?
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    I'd say it's a hardware issue. Do you still have warranty on the handset?
    thanks for reply
    well, before to install android 2.1 I had not this problem, and when I replace the installation of the recovery I solve at the moment the problem and the keyboard works great; if it was a hardware issue would I get that?
    the phone is still in warranty (it has about 4 months) but it is the american version and I am in italy, so I don't know if a can use the warranty!!!
    Senior Member jmgib's Avatar
    Kentucky
    Did the problem start when you upgraded the phone or when you tried to root and modify the phone?
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    Are you trying to use the American ROM on the device or the Italian version? I think different regions have QWERTY and some have AZERTY... ? But if it started after you changed the software, then I guess it's not hardware then.
    the problem starts when I upgrated to android 2.1. I rooted it only after the problem to try to solve the problem.
    @Dorian
    the ROM is american, but I think it is not the problem, because in italy we use also QWERTY version of keyboard
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    Oh, well hmm... IDK? What about going back to the stock ROM image? Then see if your issues persist?
    mmmm what is IDK?
    I tried already to flash the OEM firmware "att-motus-endive-3.0.1390-secure-production-supermonster-customer.sbf" with RSD lite.
att-motus-endive-3.0.1390-secure-production-supermonster-customer.sb una version similar
can you install american stock oem on british motorola mb300
flash por rsd motorola backflip
having problems rooting my backflip 2.1
how to install firmware motorola mb300 rsd lite
mb300 after install azerty patch
mb300 security on fastboot disabled
moto backflip keyboard problems
motorola backflip sbf
motorola backflip security on fastboot disabled
motorola mb300 fastboot
motorola mb300 security on fastboot disabled
root backflip recovery flasher clockworkmod recovery security on, fastboot disabled
security on fastboot disabled mb300
