Memory card problems in the backflip
This is a discussion on Memory card problems in the backflip within the Motorola Backflip forums, part of the Motorola Android Phones category; I accidently toke my memory card out of the phone without turning the phone off and now the music and pictures are not showing up ...
Thread: Memory card problems in the backflip
    Junior Member kerria_jordan's Avatar
    Unhappy Memory card problems in the backflip
    I accidently toke my memory card out of the phone without turning the phone off and now the music and pictures are not showing up is there anyway I could possibly get them back??
    Member dtowngangsta's Avatar
    Flint, MI
    Sorry but there is no way to my knowledge to get them back. You have to reformat the card and that'll erase everything on it.
    [\Marvin the Martian/]:blur:
    Senior Member jmgib's Avatar
    Kentucky
    You may not have to format the card. Have you attempted to restart your phone with the card in?
    Also, do you happen to have an sdcard reader in your PC? If so, try to mount the card in your PC to see if your data is still there.
    deleted by author
    You could always try to mount the phone as a USB Drive on your PC and check to see if the data is there or not. You can take the SD card out of the phone when it is on though. Settings->SD Card and Phone Storage->Unmount SD Card.
  1. How to Convert Movies to MPEG-4, H.264 or AVI Supported by PSP
    Last Post: 12-23-2010, 12:31 AM
  2. Keyboard issues
    Last Post: 12-15-2010, 02:46 PM
  3. task manager
    Last Post: 09-04-2010, 01:53 PM
how to format memory card on motorola backflip having trouble
mb300 memory card not detect
memory card not readable in backflip
memory problem backflip
motorola backflip memory card problem
motorola backflip wont detect sd card?
motorola mb300 not seeing sd memory card
sd not showing backflip
