Need Help Rooting Motorola Bravo have tried Z4Root Super-one-click side loading
This is a discussion on Need Help Rooting Motorola Bravo have tried Z4Root Super-one-click side loading within the Motorola Bravo forums, part of the Motorola Android Phones category; I purchased my Motorola Bravo recently and as soon as I turned it on it updated and pulled down Android 2.2.1, then I talked to ...
Thread: Need Help Rooting Motorola Bravo have tried Z4Root Super-one-click side loading
    Android Lurker waynepmyers's Avatar
    I purchased my Motorola Bravo recently and as soon as I turned it on it updated and pulled down Android 2.2.1, then I talked to my best friend and he told me about rooting the phone, I have been trying ever since, first I tried Z4Root, but since I can't install anything from an "unknown source" that won't work. Then my friend told me about side loading, I downloaded super one click onto my PC and the Android SDK claims that I do not have the Java SE JDK on my system, so I uninstalled all Java software off my system and installed Java SE JDK 6(am running Windows XP Pro) and JDK 7, now Netbeans 7 also requires Java SE JDK to be present to install so after uninstalling everything Java and reinstalling Java SE JDK 6 and 7 and installed Netbeans 7 without a hitch. So does anyone have another idea?? Just for backgrounds sake I have been working with Linux years before the first release and know Linus Torvaldus, so I am not a newbee to anything Linux have also use Minux witch was before Linux and have worked with Unix long before. So I do have some knowledge, but am at a loss since none of the instructions that I have found to date work on my phone. Any and all help would be greatly appreciated.
    Wayne
    Android Lurker heatherprotz's Avatar
    Apr 2012
    Get help from the retailer. Do not try it yourself.
how can you root the motorola bravo 2.2.1
how to root motorola bravo 2.2.1
how to root motorola bravo 2.2.1 superoneclick
how to root my motorola bravo
java motorola bravo
motorola bravo root one click
root droid bravo with superoneclick
root motorola bravo 2.2.1 unknown sources
root motorola bravo super 1 click
rooting a motorola bravo with super one click
superoneclick motorola bravo 2.2.1
z4root motorola bravo
z4rootsuperoneclick
