Want to Retire Defy if Battery Keeps Draining Fast
This is a discussion on Want to Retire Defy if Battery Keeps Draining Fast within the Motorola Defy forums, part of the Motorola Android Phones category; Use my defy for over 1 years already and now battery life is the biggest problem even though gps/wifi off on still drains half power ...
Thread: Want to Retire Defy if Battery Keeps Draining Fast
    Android Lurker middle's Avatar
    Oct 2013
    Use my defy for over 1 years already and now battery life is the biggest problem even though gps/wifi off on still drains half power in 6 hours time. Did a hard reset, reformatted SD card, turned off all of the bloatware, turned on power-saving, doesn't seem to help. Already ordered a mpj 2500mah battery to see if the stock battery is the culprit, or i may retire it, just annoying this. any advice on the battery life is welcomed!
    Super Moderator cali's Avatar
    Sep 2011
    330 times
    Welcome to the site. Sounds like the original battery needs replacing. I would go with the new battery if that fixes the problem, or you could use this as a reason to get a new phone. Either way, hope you get back to a good working phone.
    518 times
    Welcome aboard!
    Android Lurker musey's Avatar
    Nov 2013
    I just updated to Note 3 from defy. Did the battery work?
  1. Need Help, Android System Draining Most of My Battery
    By moeg84 in forum Rescue Squad Help
    Last Post: 08-30-2012, 03:34 PM
  2. Battery draining
    By princecoco in forum Nexus One Tech Issues / Bug Reports
    Last Post: 08-11-2011, 03:21 AM
  3. charger draining battery?
    By klorenz in forum LG Ally Help
    Last Post: 11-02-2010, 08:24 PM
motorola defy battery draining
