I have my D2G Rooted with custom rom With juice defender makes the battery life epic
This is a discussion on I have my D2G Rooted with custom rom With juice defender makes the battery life epic within the Motorola Droid 2 Global forums, part of the Motorola Android Phones category; I have my D2G Rooted with custom rom With juice defender makes the battery life epic I have had it for about 2 days & ...
Thread: I have my D2G Rooted with custom rom With juice defender makes the battery life epic
    Android Lurker ANDROID~GeTs~R~DoNe's Avatar
    SouthWest,FL
    I have had it for about 2 days & I also use quick clock & jrummys overclock quick clock for the best custom battery frequincies The jrummys overclock app for profiles ...Then i use juice defender on aggresive all these apps can be found in the android market
    My battery life is at 20% after 48 hours of no Charging
    Android Lurker pandapaul's Avatar
    Quote Originally Posted by ANDROID~GeTs~R~DoNe View Post
    That's impressive. Glad QuickClock was able to help get you there.
    Rescue Squad Quicksilver7714's Avatar
    Michigan
    10 times
    That's the best battery life i believe anyone has reported so far on the D2G. Everyone else is complaining about battery life of less than 12 hours. I just have ones question for you, how much are you using your phone. I just recorded a 2 day battery life on my Droid X with minimal usage that left me at 10% battery.
    I just thought of another question, so you have the stock battery or an extended battery?
    Sent from my Droid using Android.net App
    New to Android or just need a refresher course, Abe has you covered
    "Guidelines of Conduct" for Android.net
    Respect is number 1 in the Forums.
    We are the droid owners
    Resistance is Futile, YOU Will be Assimilated...
    SouthWest,FL
    I have stock battery
    The usage in my opinion heavy to moderate ....such as playing music with Power amp for about 4 hours talk time 30 mins about 100-300 text messages also some youtube time as well i also use the CDMA not global network as I switched to cdma noticed the bars went down all good though as I dialed *228 & pressed 2 witch updates your roaming capibilites & improved my coverage to 3 bars ...also i did use my bluetooth for about a hour a day as well
    Android Sr Member Hawaiian Princess's Avatar
    Oahu
    6 times
    I wont disagree. I use juice defender, moderate user, I get anywhere between 15-23 hours before charging.
    get ultimate juice for little extra and .... im using stock battery. no extended here
    Sent from my DROID2 GLOBAL using Android.net App
    Swyped with an ALOHA from Hawaii
  1. [HOW TO] Optimize Battery Life
    By WugFresh in forum Android Forum
    Last Post: 01-19-2011, 09:14 PM
  2. Battery for Epic 4G
    Last Post: 12-17-2010, 07:02 PM
  3. Battery Life + Info Re: Desktop Dock
    Last Post: 09-06-2010, 07:57 AM
  4. Battery life is terable
    Last Post: 09-04-2010, 09:36 AM
  5. Samsung Epic 4G - Already Rooted!
    Last Post: 08-29-2010, 07:26 PM
best custom rom for droid 2 global
best d2g rom
best d2g roms
best rom for d2g
custom roms for droid 2 global
custom roms for motorola droid 2 global
d2g custom rom
d2g custom roms
d2g rom
d2g roms
droid 2 global custom rom
droid 2 global custom roms
motorola droid 2 global custom rom
roms for d2g
