Extended Battery
This is a discussion on Extended Battery within the Motorola Droid 2 Global forums, part of the Motorola Android Phones category; Any one using an extended battery. If so which one and do you need a different back with it....
Thread: Extended Battery
    Android Lurker KUJO's Avatar
    Clearwater, FL
    Extended Battery
    Android Master tp76's Avatar
    Alternate Reality
    52 times
    androiddotnet
    I have one on my D1 - 2800Mah by Seidio, it does however come with an alternate backing cover, the whole thing makes my phone huge - but the battery life is beastly
    Clearwater, FL
    Thanks for the reply. I have decided to just go with a spare battery and bought a mini battery only charger (20 bucks at veizon) because I could not find a case that would fit an extended battery. I am rough on my phones so a protective case was more important to me.
    Android Lurker pastorgadget's Avatar
    Quote Originally Posted by KUJO View Post
    I bought the stock Motorola 1850 mAh extended battery through my local Verizon store, and it came with a matching back for my white D2G. Plus, it fits the standard case offered by Verizon. (I bought a clear case, to show off all my phone's pearly whiteness.) The downside is that with my D2G in a case, I had to make some small adjustments to the edges of the Motorola D2 car dock so that my phone with case would sit in far enough to actually take a charge from the USB plug. I dropped my encased phone just yesterday--HORROR!--and it's just fine. Plus, with the extended battery, I find I am getting a full day of use without charging.
    Android Lurker litigious's Avatar
  1. [HOW TO] Optimize Battery Life
    By WugFresh in forum Android Forum
    Last Post: 01-19-2011, 09:14 PM
  2. T-Mobile G2 Battery?
    Last Post: 01-05-2011, 08:01 AM
  3. Battery compatibility & capacities???
    Last Post: 12-21-2010, 05:37 AM
  4. Battery for Epic 4G
    Last Post: 12-17-2010, 07:02 PM
  5. Buy a Second battery
    Last Post: 12-02-2010, 06:44 PM
android 2 global extended battery
atrix 2 protective case for extended battery
atrix case for extended battery
atrix extended battery
atrix extended battery case
atrix extended battery protective case
customhtccase.wordpress.com
droid 2 global case extended battery
extended battery atrix
extended battery for atrix
htc thunderbolt extended battery case
htc thunderbolt extended battery protective case
protective case for extended battery motorola atrix 2
thunderbolt extended battery cases
