double antenna?
This is a discussion on double antenna? within the Motorola Droid X forums, part of the Motorola Android Phones category; Originally Posted by Ubermicro13 Are you a member of Daft Punk? Sent from my DROIDX using Android.net App No, why?...
Results 11 to 18 of 18
Thread: double antenna?
    Themer htc(hot-taco-cheese)'s Avatar
    9 times
    hotTACOcheese
    Quote Originally Posted by Ubermicro13 View Post
    No, why?
    There is not much to look at in this signature.
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    Quote Originally Posted by cruckus View Post
    I can see that that makes since but like I had said I had better signal with different roms then others maybe they put up a new tower by my house but I live in a dead zone but I have great coverage everywhere else
    The actual antennas are only half the equation. There are software algorithms that change from ROM version to ROM version... then you have different radio versions as well.
    Android Lurker cruckus's Avatar
    Yea but is it possible to change the radios on the x?
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    They're included in OTA updates, as well as version changes... like 2.2 to 2.2 update1. The radio firmware on Motorola's are like the bootloader... non-user changeable, and non-downgradable.
    Android Jr Member Blueduck3285's Avatar
    Colorado
    I know this may be a little off the topic but didnt want to create a new thread just for this but, is anyone noticing that wifi and 3G dont play nice. If my 3G goes in and out because I'm in the basement of a giant building, when I do get service my wifi drops, or sometimes ill have service and my wifi seems to kill my service. Any thoughts? Rooted stock rom.
    Well I know with wifi it disables 3g but you'll still have the 1x reception I guess it does it for the reason 3g is just data and with wifi there is no need for you to use 3g coverage also I haven't noticed anything having to do with reception loss with both enabled
    Colorado
    I have problems where both will drop out and one will re-enable before the other and work for a bit then drop out again. Its as if my phone is trying to connect to 3g while my wifi is enabled and killing my wifi. I have no problems when my wifi is off. Just seems odd that I cant have wifi up (though I do have the unlimited package from verizon).
    Yea I dunno man maybe the spots where wifi is weak cause the phone to think 3g would be better but I've never experienced what your saying so I can't say for sure
android antenna booster app
antenna boost for my android
antenna booster download for droid x 2
boost droid x signal
droid x wireless antenna location
how can i attach an antenna to my motorola milestone x?
how can i get better signal on my motorola milestone x
how to increase droid x signal
how to increase signal strength on my droid x
milestone x antenna location
milestone x signal booster
motorola milestone x2 antenna
software download for antenna booster for androi
where's the antenna on milestone x
wheres the antenna on milestone x
