double antenna?
This is a discussion on double antenna? within the Motorola Droid X forums, part of the Motorola Android Phones category; Now the Droid x is supposed to have double antenna technology so I've heard but it seems like I get the same reception as all ...
Results 1 to 10 of 18
Thread: double antenna?
    Android Lurker cruckus's Avatar
    double antenna?
    Now the Droid x is supposed to have double antenna technology so I've heard but it seems like I get the same reception as all my other phones? Anyone know anything about the antenna technology in the phone?
    Moderator/RS Abe21599's Avatar
    13 times
    i think this dates back the the iphone 4 when it had antenna troubles about how it was held. dont think its gonna improve service, just maybe not lose service as opposed to one antenna phones..?
    Android Lurker Inkarnit's Avatar
    Virginia Beach, VA soon to be Phoenix, AZ
    Quote Originally Posted by cruckus View Post
    Quote Originally Posted by Abe21599 View Post
    I think Abe is spot on here. The 2 antennas don't necessarily provide increased signal strength so much as reduce the ability to attenuate your signal artificially. Holding the phone from the bottom will leave the top antenna fully able while holding it from the top leaves the bottom alone. Technically, you could actually have the same signal attenuation as the iPhone 4, but you would have to hold it like a crack monkey with paralytic arthritis.
    Well that's true but on some roms I had an increase in signal so it was strange plus apple said the evo and the x had the same problem so my friend who has the evo did the grab the top method and his signal went down so I grab the whole top and bottom of the x and no signal drop! The x is a beast that's all but was just wondering and thanks for the insight
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    Dual diversity antennas that are found in the X are put there to help bring an equilibrium to fluctuating signal strengths. You know on some phones, you can stand in one spot and just watch the signal bars go up and down without you moving an inch? That's what the X's antennas help with. They keep a more consistent signal in a "geographical location". They don't actually provide _much_ of a boost in actual signal strength, but they do help with the radio interference caused by the "deathgrip".
    Moderator x-tac23's Avatar
    deep in the heart of texas!
    2 times
    Well they were saying that the droid x suffers from the death grip also. I didnt have the same result as the video!
    IF YOU NEED HELP WE ARE HERE!
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    Quote Originally Posted by x-tac23 View Post
    I have tested the X, and from my tests I can't get it to drop but, maybe, 5dBm. That's with very expensive company equipment... I'd say the X has one of the better antenna designs I've seen.
    Themer htc(hot-taco-cheese)'s Avatar
    9 times
    hotTACOcheese
    My incredible refuses lose any signal no matter how I hold it. It actually gains signal when I hold it.
    Sent from my ADR6300 using Android.net App
    There is not much to look at in this signature.
    Android Jr Member Ubermicro13's Avatar
    Massachusetts
    Quote Originally Posted by htc(hot-taco-cheese) View Post
    Are you a member of Daft Punk?
    Sent from my DROIDX using Android.net App
    Quote Originally Posted by Dorian View Post
    I can see that that makes since but like I had said I had better signal with different roms then others maybe they put up a new tower by my house but I live in a dead zone but I have great coverage everywhere else
android antenna booster app
antenna boost for my android
antenna booster download for droid x 2
boost droid x signal
droid x wireless antenna location
how can i attach an antenna to my motorola milestone x?
how can i get better signal on my motorola milestone x
how to increase droid x signal
how to increase signal strength on my droid x
milestone x antenna location
milestone x signal booster
motorola milestone x2 antenna
software download for antenna booster for androi
where's the antenna on milestone x
wheres the antenna on milestone x
