aux and car radio?
This is a discussion on aux and car radio? within the Motorola Droid X forums, part of the Motorola Android Phones category; Does anyone know how to make the auxiliary output play in stereo instead of mono through the car radio?...
Results 1 to 10 of 13
Thread: aux and car radio?
    Android Lurker cruckus's Avatar
    aux and car radio?
    Rescue Squad 1KDS's Avatar
    5 times
    it should do that by default
    Rescue Squad Quicksilver7714's Avatar
    Michigan
    10 times
    The output should be in stereo unless the music was formatted in mono.
    Sent from my Droid using Tapatalk
    New to Android or just need a refresher course, Abe has you covered
    "Guidelines of Conduct" for Android.net
    Respect is number 1 in the Forums.
    We are the droid owners
    Resistance is Futile, YOU Will be Assimilated...
    Android Lurker Nods_Dad's Avatar
    As others have said...output is stereo....if your getting mono check your cable
    Sent from my DROID2 using Tapatalk
    Android Enthusiast Martin030908's Avatar
    6 times
    default output is stereo. its sending the same signal to your car stereo that it is if you plug in headphones.
    Sent from my Droid using Android.net App
    Android Lurker Jason Waters's Avatar
    Upgrade to a Bluetooth enabled radio.. I did and it's amazing, especially with PowerAMP.
    I think my head unit must be messed up then cause my blackberry and evo all come out the left side only so I just use my x to give my ipod wifi for pandora and its an older version which still has no commercials plus its plug in makes it stereo but I do need to get a blue tooth radio. Decisions...decisions haha
    Android Lurker lennydude's Avatar
    I found that i needed to trim the plastic arounf the base of the plug where it goes into the phone so it would fully seat.
    You most likely know but the mono plug has one black ring and the stereo plug has two.Name:  Publication1.jpg
    197 times
    FurryVarmint
    Helpful tip, lennydude! Thanks!
    DO NOT WRITE IN THIS SPACE
    Android Lurker bsbabcock's Avatar
    Apr 2011
    Now what would be reeeeeally cool is if the phone could output a line level signal that works better with aux inputs rather than headphone level signal.
    Still you'll be at the mercy of the sound quality outputted by a "phone" as opposed to an audiophile level device, but I'd bet it hangs relatively close to an iPod in many respects.
  1. Radio Shack selling the HTC EVO Shift Early
    By danDroid in forum HTC EVO Shift
    Last Post: 01-05-2011, 12:28 PM
  2. Radio Shack offers T-Mobile G2 For $149
    Last Post: 09-14-2010, 06:43 PM
android 6000cd aux not working
android aux application
android aux car
android aux mono
android aux out
android sound aux output
aux app android
aux app for android
aux out droid 4 mono
aux out wont work
auxiliary output for car
car radio aux mono
droid 4 aux out
my aux cord wont work with my tablet
the auxillary plug in my saab wont work on my android
