Wi-fi problem
This is a discussion on Wi-fi problem within the Motorola Droid X forums, part of the Motorola Android Phones category; My wi-fi repeatedly connects and drops. Just got the DX on Monday and have had no luck staying connected to my Buffalo N router. Anyone ...
Thread: Wi-fi problem
    Android Lurker Jef-Droid's Avatar
    WNY
    Wi-fi problem
    My wi-fi repeatedly connects and drops. Just got the DX on Monday and have had no luck staying connected to my Buffalo N router. Anyone else having problems or better yet know the solution?
    Sent from my DROIDX using Android.net App
    Android Sr Member phillycodehound's Avatar
    Philadelphia, PA USA
    sethgoldstein
    It happens to me too. I do connect sometimes but not all the time. I have a Linksys N router.
    197 times
    FurryVarmint
    Are you running some kind of encryption on the network? If so, what kind? Do you have the same problem with the encryption turned off?
    WNY
    For me the issue was encryption type. I had to switch from wpa2 psk ars to wpa2 psk tkip. I had to make this change on my buffalo n, a netgear g, and a 3Com g router. Since then no problems.
    WNY
    Sorry. Aes not ar.
    197 times
    FurryVarmint
    Thanks, Jef-Droid! By the way, I do love that avatar.
    I can never remember which encryption type works on these phones.
    WNY
    You're welcome. I hope it helps you.
  1. Screen Problem, anyone else have a "rattling" screen?
    Last Post: 11-30-2010, 04:41 PM
  2. Replies: 11
    Last Post: 10-02-2010, 10:40 PM
android having trouble staying connected
android wifi problem buffalo
droid wifi attachments issues
droid wifi drops repeatedly
droid x not staying connected to wifi
droid x wi fi problems
motorola droid wifi problems
samsung epic drops wifi
thrive wireless dropping
thrive wireless drops
toshiba thrive dropping wifi
toshiba thrive not connecting to wifi
toshiba thrive wifi issues
toshiba thrive wifi problem
toshiba thrive wifi problems
