How Can I Speed Up My Droid X
This is a discussion on How Can I Speed Up My Droid X within the Motorola Droid X forums, part of the Motorola Android Phones category; Hey! My Droid X is starting to get a little sluggish. I have a lot of apps installed but I've done my best to keep ...
Results 1 to 10 of 10
Thread: How Can I Speed Up My Droid X
    Android Sr Member phillycodehound's Avatar
    Philadelphia, PA USA
    sethgoldstein
    Hey!
    My Droid X is starting to get a little sluggish. I have a lot of apps installed but I've done my best to keep them paired down as to not slow down the machine. But it still seems to be a bit jumpy and not always responsive. Do you guys know of an app or something I can do to make my Droid X faster and more nimble?
    Please let me know! Thanks!
    Android Lurker Droid Firefighter's Avatar
    You can root it then install a custom kernel to overclock the CPU. Aside from that an occasional reboot helps as well.
    Sent from my Droid using Android.net App
    190 times
    FurryVarmint
    Get rid of all the widgets you can, and try a replacement launcher app like ADW or LauncherPro to get rid of most of the Blur. If you're rooted try overclocking the phone. However, at present you cannot use a custom kernel on your phone as any attempt would fail or trigger the eFuse, forcing an expensive reset at the Motorola factory.
    sethgoldstein
    I have my phone rooted. The problem I don't want to kill my already sucky battery. The restarts help. Sometimes my phone just gives up and does it itself. Annoying but I guess it needs it.
    190 times
    FurryVarmint
    Try doing a power cycle to help with the battery. You do this by letting the battery run down till it powers off, then charging it up all the way up to full without interruption.
    Administrator wicked's Avatar
    San Jose CA.
    245 times
    wwickedd
    Quote Originally Posted by phillycodehound View Post
    Are you on stock? Have you thought of flashing a custom ROM? There's a couple good ROMS for the X that'll give you good battery life.
    Check out our sister site dedicated to the Droid X : DroidXForums
    sethgoldstein
    That's a good idea, but I really don't want to risk not getting the next 2.4 update. Will this cause it?
    San Jose CA.
    245 times
    wwickedd
    No worries, once you root you can make a stock backup which you can restore before taking an OTA update. There's also the "maderstcok" zip file you can flash to get back to complete stock. Check out the DX forums link I posted above... all the info you need is there.
    Lots to read over there and post any questions that you may have, and we'll help you along the way.
    190 times
    FurryVarmint
    Worst case scenario? There will be SBF files that you can use to put it all back for whatever you need.
    Android Lurker joe cool's Avatar
    Perrysburg, OH
    Use a brightness wiget. turn the screen all the way down and only turn it up when you need to. ROOT/install Jrummy's OC (there are others, this one is my fav.) then try different ultra low volt and low volt settings. I get 15 to 16hrs with moderate use and still at 40%. Keep in mind every phone overclocks differently dont just use the same settings some one else has, you have to try different settings for a day or two and see how your phone behaves. Also keep in mind that while this is called overclocking, you can actually run your phone at the stock speed just at a lower voltage (underclocking)
  1. Network Speed By Location
    By TMODroids User in forum Nexus One
    Last Post: 10-29-2012, 08:29 AM
  2. Replies: 18
    Last Post: 05-02-2011, 09:35 AM
  3. 4G Speed Tests Show Samsung Galaxy S 4G as Winner
    By wicked in forum Samsung Galaxy 4G
    Last Post: 02-10-2011, 07:25 PM
  4. Replies: 0
    Last Post: 02-09-2011, 12:03 AM
droid x speed up
how can i speed up my droid x
how do i speed up my droid x
how to make droid x faster
how to make my droid x faster
how to speed up a droid x
how to speed up droid x
how to speed up motorola droid x
how to speed up my droid x
how to speed up my droid x2
how to speed up your droid x
speed up droid x
speed up droid x2
speed up my droid x
speeding up droid x
