dragonzkiller presents:
CyanogenMod 10.0.0-RC0 For the Droid X2
An Android 4.1.1 Jellybean Experience
  • Pop-up Text Message Notifications
  • Lockscreen Customization
  • Status Bar/Pulldown Customization
  • Homescreen/Drawer Customization
  • Themes
  • Profiles
  • Hard Button Key Remapping
  • Quiet Hours
  • And ALL the Jellybean Featues: Google Now, Smarter Keyboard, Notifications Overhaul, and much much more!
Working:
  • WiFi
  • Bluetooth
  • 3G
  • Calling
  • GPS
  • Google Now
  • Audio System! (This was the biggest thing keeping me from releasing CM10.)
  • Camera..... ish (See known issues)
  • Maps (You won't end up in a lake in Norway on your trip to the movie theater)
Note: Internal SD is now /storage/sdcard0 and External SD is now /storage/sdcard1
New to Alpha 2:
  • New Advanced Settings Menu: This contains settings that will EVENTUALLY be added as time goes on. The only setting that works at the moment is the Hardware Acceleration. Don't get the hopes up just yet about HDMI Audio or the switchable memory yet.
  • New WiFi Module: This module is FAST. It connects in a snap and supposedly has faster download speeds. Don't quote me on the download speed as the people testing it said it. I can vouch for the connection times though.
Known Issues:
  • Recovery: Recovery has been fixed in Alpha 2, but flashing ROMs doesn't work. Restoring nandroids will work fine however.
  • Bluesleep/Deep Sleep: at it's current state, Alpha 2 doesn't have the bluesleep fix in it. This is because when it is enabled the proximity sensor doesn't turn the screen back on when it's supposed to also causing the phone call to kill audio. This problem can also occur by toggling bluetooth ("fixing the bluesleep"). The only known work around is to press the home button and swipe your finger across the sensor. Thanks to 32BitWhore for the help.
  • Stability: While not exactly an issue as CM10 is INCREDIBLY more stable than CM9, that doesn't mean that it's 100% yet. As of now, I've only had the broswer crash twice and the notification drawer flicker once. Your milage will vary.
  • Camera: At it's current state, the camcorder will not work like in CM9. I can't really do much about that for the moment or at all.
  • Some ICS/JB Apps Will Crash: This is noticeable on Chrome for example. This is because our drivers don't have External OES Textures. Basically that means when the apps want to draw using them (such as with Chrome's tab preview) the app will crash. This is the same problem on CM9/ICS. There is nothing we can do.
  • Data usage: Just don't ask me. I might get to it again one day. We'll see.
Installation:
This can be installed over CM7/CM9 or BLUR but you MUST wipe data and cache if from CM7/BLUR. (CM9 should work w/o wipe, but it's untested).
  1. READ THE ENTIRE POST
  2. Download the links provided below and put it on the External SD Card
  3. Install the BSR (patched if on an AOSP based ROM, unpatched if on BLUR)
  4. Reboot into the BSR
  5. NANDROID
  6. Install the CM10 zip from the SD Card
  7. Install the GAPPS from the SD Card
  8. MILESTONE X2 USERS ONLY: Install the WiFi patch from the SD Card
  9. Wipe both DATA and CACHE if coming from BLUR or CM7 (no need to wipe Dalvik if you wipe both of these)
  10. Reboot your phone
  11. Enjoy a better phone experience
Downloads:
Also, if you would like (but not needed) to donate, see the donate button by my (dragonzkiller) name. Gas/food money goes a long way
I am not responsible for what you do to your phone. Flash at your own risk.
REQUIRED
Google Apps (GAPPS): Goo.im Downloads - Browsing gapps. Download the latest Jellybean version of them for here and check the MD5 sums from there also.
MUST SBF IF COMING FROM A1.
CyanogenMod 10-20121007-Daytona Alpha 2: Dev-Host - cm-10-20121007-UNOFFICIAL-daytona.zip - The Ultimate Free File Hosting / File Sharing Service
Milestone X2 WiFi Patch (for all versions of 10): Dev-Host - MX2_CM9_WIFI.zip - The Ultimate Free File Hosting / File Sharing Service
Changelog:
Alpha 2:
Fix SD Card apps
Fixed camera app
Added Advanced Settings (only HWA working)
New WIFI Module (DX2 only)
mediaserver (apparently) fixed
Alpha 1:
First Public Release
Download: CyanogenMod 10-20120928-Daytona Alpha1: Dev-Host - cm-10-20120928-UNOFFICIAL-daytona.zip - The Ultimate Free File Hosting / File Sharing Service
*I, nor Android.net are responsible for what you do with your device*
