20 Tips to Improve Battery Life
This is a discussion on 20 Tips to Improve Battery Life within the Motorola i1 forums, part of the Motorola Android Phones category; Through my relentless Googling of all things EVO I came across a neat little site called goodandevo.net and today they posted a great blog about ...
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: 20 Tips to Improve Battery Life
    Through my relentless Googling of all things EVO I came across a neat little site called goodandevo.net and today they posted a great blog about getting the most out of your EVO's battery. This is a repost of the tips section of that blog.
    1. Lower screen brightness. Go to Settings -> Sound & display -> Brightness. Slide the brightness switch to the left to lower it or check the "Automatic brightness" box to let the EVO use its sensors to adjust the screen according to the ambient light. You can also find dedicated screen brightness widgets in Android Market.
    2. Turn off 4G, WiFi, GPS, and Bluetooth when you don't need them. The easiest way to manage these wireless radios is to use the Settings widget preinstalled on your EVO. Tap the + button on your home screen -> Widget -> Settings. Once your chosen widgets are on any of your home screens, a simple tap turns each one on/off. There are other widgets that do this in Android Market, but these are already preinstalled and they're a nice-looking set.
    3. Disable WiFi and 4G network notifications. Go to Settings -> Wireless & networks -> Wi-Fi settings. Uncheck the Network notification box so the EVO isn't constantly scanning and looking for open networks to tell you about. For 4G, go to Settings -> Wireless & networks -> 4G settings.
    4. Disable "always on" mobile data. This is one of the biggest battery savers. Go to Settings -> Wireless & networks -> Mobile networks. Tap "Enable always-on mobile data" to uncheck the box. I haven't found a negative consequence of disabling this feature, as Gmail and other apps/functions still work perfectly.
    5. Turn off background data. If you're not using Google services, go to Settings -> Accounts & sync and uncheck the Background data box so that applications cannot sync, send, and receive data whenever they want to.
    6. Lower the screen timeout interval. The EVO's screen can be set to automatically turn off when you don't interact with it for a predetermined amount of time: 15 seconds, 30 seconds, 1 minute, 2 minutes, 10 minutes, or never. Depending on what you're doing, a too-short interval can become annoying (especially if you didn't disable your lock screen), so choose wisely.
    7. Manually turn off the screen when not in use. Since the screen timeout function ensures that the EVO's screen will turn off (unless you have it set to "never turn off"), it can be tempting to put the phone down when you're done using it and just let the screen turn off by itself. Instead, give the power button at the top of the EVO a quick push to turn it off manually.
    8. Turn off auto-sync. Go to Settings -> Accounts & sync -> Auto-sync.
    9. Change auto-sync frequency (Weather, News, Stocks, Twitter, etc). If you don't want to turn off auto-sync, you can adjust how frequently data is retrieved/updated. The settings vary depending on the app (and some don't offer the setting at all), but it's generally found in the same place: Settings -> Accounts & sync. Select an account from the list and then tap "Account settings" to change the sync frequency.
    10. Disable wireless network location services when not needed. Go to Settings -> Location -> Use wireless networks. Note that this (or one of the other options) needs to be enabled if you want to see and/or use your location in apps like Maps.
    11. Turn off window animations. I know it's nice to look at and fun to show off, but eye candy uses extra power (albeit not very much). To turn it off, go to Settings -> Sound & display -> Animation -> No animations.
    12. Don't use a live wallpaper. Live wallpapers were one of the new features in Android 2.1, so it feels like a step backward not to use them. They don't hit the battery very hard when used, but they do make a small dent. So if you're trying to improve battery life, even if only incrementally, use a static wallpaper instead.
    13. Use a dark wallpaper. Some say that dark wallpapers are more energy efficient than light wallpapers. Others say it doesn't make any difference. Either way, there's no harm in using a dark wallpaper so you may as well do it.
    14. Change WiFi sleep policy. This may sound counter-intuitive, but leaving WiFi on when the EVO isn't being used and the screen is off is actually better than letting it sleep. When WiFi sleeps, 3G/4G wakes up to sync, get email, and retrieve other data. 3G will eat up more battery than WiFi, so go to Settings -> Wireless & networks -> Wi-Fi Settings. Press the Menu button and tap Advanced, then Wi-Fi sleep policy. Choose "Never" from the pop-up menu.
    15. Monitor your running services (or consider using a task killer). Just because Android 2.1 is supposed to an intelligent operating system that will manage your running apps for you doesn't mean it will always do things the way you want them to be done.
    You can take matters into your own hands by going to Settings -> Applications -> Running services, where you can view what your EVO is doing and manually stop certain activities. You can also download a third-party task killer from Android Market and kill selected apps to free up some resources and potentially save some power. Task killers are a polarizing topic in the Android community, so tread lightly when looking for recommendations or asking for help with them.
    16. Choose your home screen widgets carefully. Widgets that need access to the internet to update information (e.g., Facebook, Twitter, Engadget, Slacker Radio, Weather, Stocks, News, Mail) can suck up a lot of juice if not managed well, so choose them carefully and set their sync/update frequencies to a reasonable interval.
    17. Disable notification lights. This may not be practical if you're someone who really needs/wants to know when something happens on your phone when you're not looking, but for everyone else, feel free to turn off those notifications. Go to Settings -> Sound & display -> Notification flash and uncheck all the boxes.
    18. Turn off phone vibration. If the ringer is on, why do you need the phone to vibrate? You're already in a loud environment that drowns out the ring; answering the call won't quiet your surroundings so you can hear what the person at the end of the line is saying. If anything, you're just adding to the noise by yelling, "What? What?" into the phone.
    And if the EVO is set to silent, then an incoming call should be silent. Yes, the buzzing vibration may not be disruptive as your ringtone, but people still hear it.
    So go to Settings -> Sound & display -> Phone vibrate and turn it off.
    19. Turn off audible touch tones. In Settings -> Sound & display, uncheck Audible selection and turn off Audible touch tones.
    20. Turn off haptic feedback. Once you get the hang of typing on the EVO's on-screen keyboard, you can turn off the haptic feedback that was turned on by default. Go to Settings -> Language & keyboard -> Touch Input -> Text input -> Vibrate when typing.
    You can disable haptics in other areas of the system by going to Settings -> Sound & display -> Haptic feedback.
    danDroid
    Guest danDroid's Avatar
    Awesome, that should help out a lot of users. Nice find!
    Member Lmontes's Avatar
    nice i sure will be doing that right when i get it.
    Here is another repost from the same blog, this time illustrating how to find out what is draining your battery:
    Built right into Android 2.1 is a handy battery usage utility that shows you an itemized list of what has been using the EVO's battery since the last time it was unplugged.
    Here's how to find it:
    Press the Menu button.
    Tap Settings.
    Scroll to the bottom of the list and press About phone.
    Then tap Battery followed by Battery use.
    An even easier way to access the information is to create a shortcut to it on one of your home screens.
    Tap + on the home screen.
    Select Shortcut from the "Add to Home" list that appears.
    Tap Settings at the bottom.
    Choose Battery use.
    When using the shortcut, tap Menu -> Refresh to display current statistics.
    Now, take a close look at that screen cap. Notice the uptime? 22+ hours and there is still 54% battery. I really don't think we are going to have too many issues with battery life.
    Junior Member Spookymonster's Avatar
    Anyone else confirm whether or not turning the phone completely off before charging improves capacity?
    Fixing the Battery Problem your Android Smartphone Seems to Have
    Junior Member ann237's Avatar
    awesome info thank you! i am excited for my evo to arrive i ordered it on line from sprint on sat!!!
    I just got mine today, you're going to be VERY happy with it
    Junior Member Grimlock1973's Avatar
    I'm going to order the Seidio extended life battery listed below as soon as it's available. That way I can have all the goodies running all the time and don't have to worry about battery life! Innocell 3500mAh Extended Life Battery
    For use with HTC EVO 4G
    Coming Soon!
    Member droidaddict_sprintdroids's Avatar
    Thanks for the battery life tips!!! I think it will help a lot since my battery drained in 1 day without using it much.
    Junior Member megawatz's Avatar
    awesome tips. We'll see how much useage I get out of my EVO now.
  1. More details on Sony's PlayStation Leak
    By danDroid in forum Sony PSP Phone
    Last Post: 01-15-2011, 08:23 AM
android get cdma roaming mode sprint
battery saving tips for htc evo 4g
cdma roaming mode
cdma roaming mode a or b
cdma roaming mode htc evo
how to save battery on htc evo 4g cdma phone
htc evo 4g battery saving tips
htc evo battery saving tips
power saving tips android evo
sprint evo battery life tips
sprint evo battery tips
tips to save battery on htc evo 4g
tips to save battery on the htc evo 4g
what does cdma roaming mode mean
