Battery widget
This is a discussion on Battery widget within the Motorola i1 forums, part of the Motorola Android Phones category; I am using a battery widget called Battery Left, It works ok, after you install it and let it calibrate, it will tell you how ...
Thread: Battery widget
    Junior Member myke_sprintdroids's Avatar
    Arrow Battery widget
    I am using a battery widget called Battery Left, It works ok, after you install it and let it calibrate, it will tell you how many hours you have until the phone will be dead and at what time it will be.
    I was just wondering if anyone is using any other widgets and what they are called? Looking for something better maybe? Can anyone recommend something they like? Maybe I should stop obsessing over the battery and stop using a widget all together?
    myke
    Android Addict jak89's Avatar
    I use mini info not cuz its a great battery widget but it shows three things, battery sd card and disk space.
    Right now I am only using the battery option for SwitchPro on one of my toggle widgets. I used to use Battery Left, it's actually pretty accurate but it's too ugly for me to use with my current homescreen set up.
android mini battery widget
calibrate a motorola i1 battery
calibrate motorola i1 battery
how to calibrate evo battery
how to calibrate the motorola i1
i1 battery widget
i1 widgets
motorola i1 widgets
motorola widget battery
widget battery i1
widgets motorola i1
widgets motorola i1 download
