Motorola Photon Battery indication
This is a discussion on Motorola Photon Battery indication within the Motorola Photon Tech Support forums, part of the Motorola Photon category; I just got the Photon on Sunday. When you go to check the battery status it is always in a 10%, like 90%, 80%, 70%, ...
Thread: Motorola Photon Battery indication
    Android Lurker CWEBBY's Avatar
    I just got the Photon on Sunday. When you go to check the battery status it is always in a 10%, like 90%, 80%, 70%, 60%, 50%, 40%, 30%, 20%, then when it gets low it goes by 5% like 15%, 10%, 5%. It never goes down by a smaller % like my HTC Hero that I traded in. I know this really shouldnt be a problem, but if it is, I would like to get it fixed sooner rather than later.
    197 times
    FurryVarmint
    Motorola and Verizon seem to like the phones doing that. I have no idea why -- even the Motorola Backflip (a subpar phone by most standards) has 1% indicators.
    It's not a problem, just kind of annoying to see how fast it drops from 100% to 90%.
    DO NOT WRITE IN THIS SPACE
    Android Lurker shainfu's Avatar
    battery level app
    for what it's worth, the App : "Gauge Battery Widget" is a pretty dope (free) on-screen battery level display widget.
    It still rocks percentages in 10's but at least you don't have to dig around your settings/revert to lock screen to find an percentage readout.
    Android Lurker basysaz's Avatar
    Phoenix AZ
    Just got my new Photon from Amazon Wireless, but the battery doesn't want to charge after several hours connected and the phone won't even start up. Plugging in the USB charge cable causes a small LED just above and to the right of the MOTO logo to come on white and then go green, but I can't find any documentation of what it means. Anybody have the color codes?
    197 times
    FurryVarmint
    Green would indicate charging, I believe.
    Dumb question -- is the SIM inserted? Is there something covering the battery contacts?
  1. Motorola Photon vs HTC EVO 3D
    By danDroid in forum Motorola Photon
    Last Post: 08-12-2011, 08:09 AM
  2. Must have Accessories for the Motorola Photon
    By danDroid in forum Motorola Photon Accessories
    Last Post: 08-06-2011, 05:47 PM
  3. Motorola Photon Unveiling
    Last Post: 06-09-2011, 12:15 PM
  4. Motorola Photon Specs
    Last Post: 06-09-2011, 12:03 PM
  5. Welcome to the Motorola Photon Forum!
    Last Post: 06-09-2011, 12:01 PM
how to show battery percentage on motorola photon
motorola atrix hd charging issue question mark
motorola electrify battery question mark
motorola photon battery not charging
motorola photon battery percentage
motorola photon battery question mark
motorola photon battery wont hold charge
motorola photon charging indicator
motorola photon charging problems
motorola photon not charging
motorola photon question mark
motorola photon wont charge
motorola photon wont hold charge
my motorola photon wont charge
