Photon 4G call problem
This is a discussion on Photon 4G call problem within the Motorola Photon forums, part of the Motorola Android Phones category; I have a new Motorola Photon 4G that will not connect a call after dialed. The phone automatically reboots itself, it works for about 4 ...
Thread: Photon 4G call problem
    Android Lurker mattbo24's Avatar
    Jan 2012
    I have a new Motorola Photon 4G that will not connect a call after dialed. The phone automatically reboots itself, it works for about 4 to 5 more calls than the problem is repeated. Has anyone else experienced this?
    Administrator cereal killer's Avatar
    Austin
    122 times
    That sounds like a hardware problem and you should consider taking it back to Sprint for a replacement. Can you replicate it on a regular basis? Meaning does it do it without fail every 4-5 calls?
    Android Lurker Willsan's Avatar
    Jan 2012
    I had this problem with my release day photon. I brought it to the a sprint "store" (non corporate), and all they offered to do was reformat it. After three reformats, the problem still occured. I contacted sprint and got a refurb replacement (which was seemingly a new phone)
    So yes, contact Sprint directly.
  1. Replies: 0
    Last Post: 01-03-2012, 12:17 AM
  2. Problem when connected to call
    By BFid in forum LG Ally Help
    Last Post: 12-14-2010, 04:15 PM
4gcall
how will i call from photon
motorola photon 4g calling error
motorola photon 4g will not call contact
motorola photon wont connect to 4g
motorola photon wont dial
photon 4g call issues
photon 4g call problems
photon 4g does not connect
photon call not connected
photon call problems
photon wont connect calls
photon wont dial calls
sprint motorola photon call not connected
sprint photon 4g wont connect calls
