Screen Protector problem
This is a discussion on Screen Protector problem within the Nexus One Accessories forums, part of the Nexus One category; Hey guys I received my N1 today and tried to put on a BSE screen protector. However.... It looks like this. Are those air bubbles ...
Thread: Screen Protector problem
    Junior Member Jujujam's Avatar
    Unhappy Screen Protector problem
    However....
    It looks like this. Are those air bubbles that are supposed to go away or did I do something wrong? I followed instructions by spraying some water/soap mixture on adhesive side and then flattening it out with the squeegee. The adhesive side never touched the table or anything. It only touched my fingers which I also sprayed with the solution. :x
    Thanks!
    Metro Atlanta
    53 times
    Those look like fingerprints to me...did you wash your hands thoroughly before you applied the skin?
    Yes I did with soap and everything. Hmm I guess I will try to take it off and reapply.
    Thanks!
    I took my screen protector off the very next day. It made the screen so much harder to use and see in certain lighting situations. Buy a micro fiber cloth and keep that with you and buy a good case or cover instead imo.:nexusx:
    I applied the Skinomi which is similar to my Nexus One. It really did take days for the bubbles to disappear. I had one bubble on the case back that was there for weeks, then one day I noticed it was gone.
    The dust motes continued to bother me on the screen, so, after about 3 weeks, I removed the Skinomi from the screen and put a Boxwave Crystal on it. It worked fine until I got rid of that phone.
    Now I have yet another Boxwave on another Nexus One. I like it. I have a problem with my silicon case pushing on the screen protector. This was made better by filing some of the edge of the silicon case away. Haven't really had a problem in the last week or so since the mod to the case.
    If I ever had a chance to get someone good to put on the Body Armor to the body of the phone, I just might do it. But I will never try Skinomi again by myself. It just never really fit correctly.
    AT&T ne:nexusx:us S on AT&T
    Archos 70 with UrukDroid
screen protector bubbles with adhesive
screen protector problems
