need nexus one car "solutions" please help!
This is a discussion on need nexus one car "solutions" please help! within the Nexus One Accessories forums, part of the Nexus One category; Okay, I used to have a nexus one car dock, but the little top part broke. I was never a huge fan of the car ...
Thread: need nexus one car "solutions" please help!
    Junior Member kevinnem's Avatar
    I was never a huge fan of the car dock as
    1) can't use the nexus to play music on my car stereo.
    2) the speaker phone was WAY too quite
    3) I couldn't use the car to listen to voice.
    So what I am looking for is a magical unit(s) to
    1) hold the phone
    2) Some way to have incoming voice, and music reproduced over my car stereo, rather then the built in speakers.
    3) this new unit(s) might need a mic, I hear the build in one works poorly while in a dock.
    My truck is a Toyota 4 runner, and has no built in blue tooth or other cabality, it doesn't have an "aux in " either, so I likely need FM transmitter.
    I assume this with be a few units, but all in would would be sexy, certainly not required though.
    It may be a little pricey but the Motorola motorkr t505 will do exactly what you are looking for.
    If you have a newer Toyo, you can plug interfaces into the back of the factory stereo - I believe 2006 onwards (or somewhere around there)...
