Car Charger
This is a discussion on Car Charger within the Nexus One Accessories forums, part of the Nexus One category; If I use USB Cigarette Lighter Adapter and USB cable that was supplied with my nexus one. Will I able to charge my phone?...
Thread: Car Charger
    Member wamchu's Avatar
    Car Charger
    Member soongteck's Avatar
    Quote Originally Posted by wamchu View Post
    i believed that it is possible as long as your adapter output adequate power.. what's the rating?
    Input DC 12 - 24 V
    Output DC 5.0 Ve 5%
    Max : 900mA
    the supplied charger should be around 980mA or 1A.
    as stated on specification: Charges at 480mA from USB, at 980mA from supplied charger
    I believe that you can't achieve 900mA. but it should be sufficient for charging unless your adapter have fluctuate voltage of 5V DC. It would be charging slower than AC adapter.
  1. How to silence ringers when on a call
    Last Post: 12-27-2010, 11:46 AM
charging nexus 4 through cigaretter lighter car
nexus 4 car charger how many ampers
