Cheap universal car mount holder that works well with my nexus one
This is a discussion on Cheap universal car mount holder that works well with my nexus one within the Nexus One Accessories forums, part of the Nexus One category; Just ordered, the goose neck one wen I get it, will post impressions...
Results 11 to 19 of 19
Thread: Cheap universal car mount holder that works well with my nexus one
    Junior Member zviangi's Avatar
    Member abe12345's Avatar
    Quote Originally Posted by zviangi View Post
    Any reviews on this one? Will it work with the bestskinsever complete skin?
    not yet, it will be in my hands after ten days. and actually I bought Amzer 8 inch Gooseneck Vehicle Mount For Google - Vehicle Mounts - Fommy.com - this, not the one I posted in my previous post, because I was not sure that one is supporting landscape rotation. this one does. i will post a small review, when I get it.
    Thanks. That one looks good. My main concern is if it will still fit after adding a rubberized hard case. Looking forward to the review.
    Junior Member OptPrime's Avatar
    got that same thing 5 bucks cheaper at cheap nexus
    Amzer® Nexus One Universal Suction Cup Mount for Windshield Dash or Console
    Quote Originally Posted by OptPrime View Post
    I think I might prefer this one because it lets you adjust the neck, and also it grabs the phone on all sides: Amzer 8 inch Gooseneck Vehicle Mount For Google - Vehicle Mounts - Fommy.com My only concern with that is will the phone fit after adding a case?
    Yours unfortunately does not have as adjustable of a neck and does not grab it on all sides. But then again it might fit better if you have a case.
    Quote Originally Posted by Roxy View Post
    Universal GPS Car Mount Holder
    I just got this few days ago and it works well with the nexus one ^_^
    Cheap too ~
    Is this secure enough in case of a car crash or very bumpy road? I worry about these designs because it seems like it is not as secure as something like this: Amzer Suction Cup Mount for Windshield, Dash or Console - 86726 - Fommy.com .
    I got 8" goose neck vehicle mount from Fommy. It can not fit cased phone. In other ways, its holding the phone quite firmly and the neck is very stiff, so no bumpy road will bend it. it has rotating holder, so you can have you phone in any position
    I will take and put pictures later
    Junior Member CardinS2U's Avatar
    thanks. I think I'll go with the 6 dollar one..its cheap
