Using Full skin and Rubber case togather?
This is a discussion on Using Full skin and Rubber case togather? within the Nexus One Accessories forums, part of the Nexus One category; I have read many reviews on skins and rubber cases but no one has mentioned using both. Does anyone do this? I was thinking doing ...
Thread: Using Full skin and Rubber case togather?
    Junior Member tbennett83's Avatar
    I have read many reviews on skins and rubber cases but no one has mentioned using both. Does anyone do this? I was thinking doing it and wondered if had tried.
    Junior Member Mines's Avatar
    It probably would not work if you bought it individually, since most quality hard shell cases should fit pretty snug. There is this alternative which uses a combination of silicon and a hard shell. https://www.case-mate.com/Google-Cas...ough-Cases.asp Watch the video towards the bottom.
    I was thinking about that but the part of the phone with the trackball isnt covered. What would you do about that?
    Member Euforeik's Avatar
    It would work fine. I'm just trying to figure out what rubber case I should get. I have the full body zagg invisible shield.
