Car charger / iGo tips
This is a discussion on Car charger / iGo tips within the Nexus One Accessories forums, part of the Nexus One category; I'm looking for a car charger for the Nexus One and I already have one of those universal iGo car chargers with the interchangeable tips. ...
Thread: Car charger / iGo tips
    Senior Member geckocavemen's Avatar
    I'm looking for a car charger for the Nexus One and I already have one of those universal iGo car chargers with the interchangeable tips. I went to their website and I believe the A97 and A138 tips use the same connection as the N1 but I can't figure out which one is for the google phone or even what the differences are between the two tips. Anyone know which works better with the Nexus One or what differentiates the two connectors?
    Senior Member ScottyPimpin's Avatar
    All you need is a micro usb tip. micro usb is 100% compatible with all micro usb chargers.
    Junior Member krazichinaman's Avatar
    I purchased the A97 tip for $9.99 from my local Radio Shack. It plugs in snug and it won't have issues of it coming off while charging.
    The one I got for $3.99 works great. Well made and the cable coils-up out of the way:
    Google Nexus One Car Charger, Car Charger For Google Nexus One
    Thanks for all the help, I'll get the A97 this weekend hopefully.
    So does anyone know what differentiates the A97 and A138 tips? They both use the micro usb connector.
    Quote Originally Posted by geckocavemen View Post
    I asked the rep at Radio Shack and didn't have a clue. Seems like most seraches that I've done, people are getting the A97.
car charger with changable tips
ends for my igo car phone charger
i go car charger tip for android phones
igo car charger tip for galaxy s4
igo car charger tips
igo car charger with changeable ends
igo car phone charger tip
igo charging tips for galaxy s4
igo tip for nexusone
radio schack interchangeable tip usb
tips for igo charger
universal threaded tip car chargers
where can i get igo a138
where can i get igo phone charger tips
which igo tip is for a htc dna
