Seidio 3200 mah super Extended Battery for Nexus One
This is a discussion on Seidio 3200 mah super Extended Battery for Nexus One within the Nexus One Accessories forums, part of the Nexus One category; @jaeisber I'll be looking for your post tomorrow that you've ordered your VZ N1. Keeping my fingers crossed that it launches tomorrow. :nexusx:...
Page 4 of 14 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 140
Thread: Seidio 3200 mah super Extended Battery for Nexus One
  1. #31
  2. #32
    Junior Member freshstart610's Avatar
    Heres a few shots comparing the 3200mah battery to the original battery
  3. #33
    @MightyTallDude and freshstart - thanks for the pics. That helps a lot.
    @MightyTallDude - dont worry, as soon as it is available, I will be purchasing the N1 and probably all available accessories.
    Bought the AT&T N1.
  4. #34
    ...and some more pics. this should give you a good idea on what to expect as far as size is concerned. A lot thicker but if making it through the day and more on a single charge is your concern it's worth it to me.
  5. #35
    Quote Originally Posted by freshstart610 View Post
    Yeah, it definitely does add a lot more size to it. I didnt realize it was that much bigger. However, it is a concern to last at least through the day. I may start off without to see how it goes. If I am not getting what I need from the stock battery, ill upgrade.
    Bought the AT&T N1.
  6. #36
    yea it really depends on usage and what additions you have turned on like live wallpaper, gps and wifi. With moderate use at 8 o clock I was at 15% constantly. It's been a good 30 hours later with the 3200 and I'm at 39%. Looks a lot better with the original battery but I want to be able to use my phone worry free.
  7. #37
    3xL
    3xL is offline
    Member 3xL's Avatar
    i found the added size to PERFECTED my phone. i've got big sexy man hands lol so the added thickness stops my typos and mistakingly opening apps. HOWEVER...
    i posted a new thread about how my new battery is worst than the stock battery (mighytalldude i pmed you)
  8. #38
    Well that is no good..I assume you are getting a replacement
    Bought the AT&T N1.
  9. #39
    3xL
    3xL is offline
    Member 3xL's Avatar
    i'm trying to trouble shoot it before heading towards my mission of replacing it. turns out i might be charge cycling wrong. i've read that i'm supposed to let the phone di.. i usually save it from dying lol
  10. #40
    yeah, it is definitely best to use the entire battery (let your phone die) 4-5 times before starting to charge it intermittently. It helps condition the battery. You should always power cycle it every now and then to keep the battery life up.
    Bought the AT&T N1.
