Battery empry in 4 hours after placing screen protector
This is a discussion on Battery empry in 4 hours after placing screen protector within the Nexus One Accessories forums, part of the Nexus One category; Two days ago i placed a screen protector on my brand new Nexus One. Within 4 hours, my battery was empty. That must be a ...
Results 1 to 10 of 14
Thread: Battery empry in 4 hours after placing screen protector
    Junior Member sassiewas's Avatar
    That must be a coincidence, you might say. Well, I thought the same thing, but after I reloaded my battery completely (in the evening) my alarm did'nt go off in the morning because.... Empty battery!
    Now i've removed the screen protector, and reloaded my battery, again.
    It's been 6 hours, and still a FULL battery.
    I think because of the the screen protector, my N1 couldn't get rid of it's warmth or something.
    Anyone had the same problem??
    Member kcs7272's Avatar
    Quote Originally Posted by sassiewas View Post
    The screen protector has absolutely nothing to do with battery life. It is a weird coincidence but trust me it is not the screen protector.
    This is exactly why I don't use a screen protector :rofl3:
    Senior Member xPatriicK's Avatar
    Quote Originally Posted by kcs7272 View Post
    +1
    @sassiewas check your battery stats in the menu/settings
    you'll see whats wasting that much battery. It could be an app or something which prevents the phone from sleeping.
    Get a taskkiller to kill the apps you dont use.
    Its not needed at all for android phones because Linux manages the background apps itself but sometimes there are apps which dont let the phone sleep.
    Follow me on Twitter @xPatriick
    Feel free to buy me a beer if I helped you
    This is what I use on my Nexus One (ROM, Kernel, special Apps)
    N1s don't need a screen protector anyway. The screen is made of glass, not plastic. There is even a video floating around youtube on a scratch test being done with keys. Not one mark on it. [ame=http://www.youtube.com/watch?v=gpGAW6L5x8U]YouTube - Nexus One- Its Scratch Resistant[/ame] Unless you rub a diamond against it you have nothing to worry about. Keep in mind it will break if you crush it, but it won't scratch from everyday use.
    is it possible that the screen protector could be causing the phone to think you are touching the screen when in reality it is just the screen protector? Just a thought, im not up on all of the touchscreen technologies and how they decipher between your pocket, a case, and your finger.
    Bought the AT&T N1.
    4 times
    Take off the screen protector and see if there are any changes.
    He did...when he took it off, after 6 hours he still had full charge
    Bought the AT&T N1.
    Quote Originally Posted by jaeisber View Post
    The screen protector should not make the phone think you are touching it. The touch screen is capacitive, it works by when you break an electric barrier (that is just the simple way to describe it)
    Member jimbobalu's Avatar
    Maybe something to do with the proximity sensor?
screen protector and battery life
screen protector battery life
