*Small* Power Control Widget?
This is a discussion on *Small* Power Control Widget? within the Nexus One Application Discussion forums, part of the Nexus One category; I am looking for a Power Control widget that takes up less room of my home screen than the one included on the phone. What ...
Thread: *Small* Power Control Widget?
    Junior Member carlsbl's Avatar
    Question *Small* Power Control Widget?
    I am looking for a Power Control widget that takes up less room of my home screen than the one included on the phone. What I do like about it is you can clearly see what is one or off. Back in the myTouch 3G days I had a small one that indicated the wifi, GPS, Bluetooth status with a red or green light. It was very narrow but I can't remember the name.
    Thanks,
    Brian
    Sounds like it was a HTC Widget?
    There are many widget controls in the Marketplace, that let you control individual controls (wifi, gps, brightness) that only take up 1x1 each.
    I don't know how the widget would get any smaller though, since it is already 4x1.
    @NEONmonstar
    Rooted NexusOne
    Cyanogen CM6 RC1 FROYO
    RA-nexus-v1.7.1-Cyan
    Galaxy S PRO Theme
    Desire Camera
    Junior Member skcaudill's Avatar
    Quote Originally Posted by carlsbl View Post
    Thanks,
    Brian
    I use Beautiful Widgets. It allows for small power buttons.
android power control widget icons small htc one
htc one power control widget gps
power control htc one android widget
power control widget 4x1
power control widget small
