circular battery indicator
This is a discussion on circular battery indicator within the Nexus One Application Discussion forums, part of the Nexus One category; Originally Posted by Zindol If i remember correctly it will ask you if you want to morph all 3 files in the rar file or ...
Results 11 to 20 of 37
Thread: circular battery indicator
    Quote Originally Posted by Zindol View Post
    If i remember correctly it will ask you if you want to morph all 3 files in the rar file or not, just select apply all.
    when i try to start morph(checks)it says busybox not installed can i get this from market?
    Senior Member Zindol's Avatar
    I have no idea what busybox is, no way of bypassing that?
    it just comes up and wont let me go any further?? i'll leave it just now as its doing my head in lol cheers for the help
    you can always use the other thread file and flash it from your zip. As always make sure you do a nandroid backup incase you dont like it though.
    ok ive flashed it but screen has been on google cross(x)and unlocked padlock sign for 5 minutes please dont tell me its f***ed??
    did you flash the kspec lite one or the morph file?
    (dont worry your phone will be alright. You can always do a nandroid restore if it flops.)
    the kspec lite one mate
    Thank God, is it still on the X and padlock?
    yes mate it is
    strange, try take the battery out, then power it on holding trackball and power button, then go fastboot then reboot and see if that happens again. If it does you may just have to do a nandroid restore.
  1. Epic 4G Root Thread
android v4.1.2 circular battery indicator
