Problem with foursquare
This is a discussion on Problem with foursquare within the Nexus One Application Discussion forums, part of the Nexus One category; when i try to load the sections i got an error saying something like unresolved : ó... and a code o direction... :S how i ...
Thread: Problem with foursquare
    Senior Member Budske's Avatar
    how i can fix it??? how i can set the time of response from the server, cos im getting timed out messages too
    Re: Problem with foursquare
    I dont really know what you mean by "load the sections" but it appears you're having a problem with the app in general. I suggest uninstalling the app, reboot Nexus One and install it again.
    I hope that helps.
