Speed Test
This is a discussion on Speed Test within the Nexus One Application Discussion forums, part of the Nexus One category; Thanks, I had forgotten how fast our T-1 line was....
Results 11 to 16 of 16
Thread: Speed Test
    getting like 300 on 3g in SD, that is home tho, will check around.
    wifi is more like 2000
    Nexus One and luvin it
    Rooted 5/6/2010
    Enomther 2.10.1 Froyo Release
    Folks, just remember that when you're doing an Internet speed test, that you're testing the entire chain. In other words, the slowest component link is the limiting factor. So there are times when it does not matter that your WiFi is super fast if the back end connection to the Internet is slow.
    Phone -> WiFi -> ISP -> internet server
    Phone -> 3G Network -> ISP -> internet server
    etc. etc.
    If the ISP link in case one is 1.5 Mbps, then the best possible speed that you'll get is 1.5 Mbps. It doesn't matter whether you have wireless B,G, or N.
    Android Lurker androidvibe's Avatar
    Apr 2011
    My wifi is almost 3 times faster than 3G at all times. Maybe all of you that have faster 3G should check into your router and internet provider. Investing in a faster router helped me. Also your internet provider may have different packages that you can get to increase your speeds on wifi.
    I pulled out my laptop the other day and the wireless speed on that came pretty close to the phone wifi speeds. I guess I need another router if I want more speed.
    Junior Member davor's Avatar
    I got here using a searcher, i been having problems with my wifi for several days and its getting worst every day. I think everytime i do a speed test my speed decreases. may it be possible? i tried opening some ports as a friend told me, can somebody help me?
  1. Battery Life + Info Re: Desktop Dock
    Last Post: 09-06-2010, 07:57 AM
1255 kbps a decent speed?
is 4015.22 kbps a good speed on my android
one seniors speed test
speed test one seniors
speedtest oneseniors com.au
speedtest oneseniors,com,au
speedtest.oneseniors.com.au
