Speed Test
This is a discussion on Speed Test within the Nexus One Application Discussion forums, part of the Nexus One category; I have noticed that my 3G seemed to be faster than my WiFi connection, so I downloaded the Speed Test app from the market and ...
Results 1 to 10 of 16
Thread: Speed Test
    Speed Test
    I have noticed that my 3G seemed to be faster than my WiFi connection, so I downloaded the Speed Test app from the market and here are the results:
    3G
    Down 1255 kbps
    Up 882 kbps
    WifI
    Down 718 kbps
    Up 219 kbps
    I ran the online version from my desktop computer just to see that one and the results for that are:
    Desktop
    Down 1.12 Mb/s
    Up 0.13 Mb/s
    Why is my 3G faster than my WiFi?
    Thanks in advance for your replies.
    Re: Speed Test
    Same with me since day one. I was puzzled too.
    Member DToX's Avatar
    3G
    Down 1255 kbps
    Up 882 kbps
    WifI
    Down 718 kbps
    Up 219 kbps
    Desktop
    Down 1.12 Mb/s
    Up 0.13 Mb/s
    You guys are crazy my Wifi just got the following
    Download: 13998kbps
    Upload 2524kbps
    I can't compare to 3G because I have the t-mobile nesus one on AT&T
    and edge tests are pathetic
    Junior Member TheFranchise's Avatar
    I just did it myself.
    Miami, FL
    3G - 438kbps
    wifi - 2645kbps
    Wifi: 4462 down, 523 up (via ADSL, hence the low up speed)
    3G: 1446 down, 905 up
    Senior Member Budske's Avatar
    i cant test 3g cos the network on my house is really bad, but i did a test in a friend's house and i got like 500 kb/s over 3g, and in my over wifi i get like 900
    Junior Member gnk2727's Avatar
    Here's my results, I use a N1 rooted with cyanogen. My wifi comes from comcast and my 3G/Edge from T-Mobile
    Wifi:
    Down: 14070 kbps
    Up: 2088 kbps
    3G/Edge:
    Down: 716 kbps
    Up: 382
    Is that good, bad or ugly?
    Junior Member aldin.aldis's Avatar
    You are running at 1.9 megs. If you are paying for 8, call your ISP and have them reset your modem. I had to do this a few weeks ago when my modem was running VERY slow.
    I checked the speeds at my office (we have a T1 line there) and WiFi at work is marginally faster than my 3G
    Work WiFi
    Down 1385
    Up 1487
    3 G while at work
    Down 1096
    Up 1156
    At home, there is a cell tower a couple of blocks away from my apartment. It is in a clock tower and I can see part of that clock when I look out my bedroom window. Would that - could that be a reason? Also, I was in the mountains and even though it is listed as a covered area on the T-Mobile map, I had no signal until I walked into town. My sister on AT&T (not a Nexus One phone) had a signal at one certain spot in the cabin. I tried standing in the same spot to see and I still didn't have a signal. I went into the Mobile Networks setting, scanned for networks and AT&T was the only one that my phone found. I tapped the AT&T listing and the screen closed. Could that have an affect?
    Last question, when I first got my Nexus One, I came from a BlackBerry and just a couple of weeks ago, I called T-Mobile for a problem (K-9 would not send any emails anymore) and my phone was still provisioned for BlackBerry they changed that to Nexus One and had me power off and on my phone and my email problem was fixed. Could that be a reason? (It seems now after that change in provisioning my 3G icon is on more regularly now). Though, at the office I can see the 3G change to Edge Icon.
    OK, a lot of questions here. Thanks in advance for your thoughts & replies.
    FYI, a T1 line is only 1.54 Mbps in both directions.
    As a comparison, my ADSL line at home is 6Mbps for download (4x the T1).
    With AT&T I've gotten very good speed wherever I've check it (on 3G).
  1. Battery Life + Info Re: Desktop Dock
    Last Post: 09-06-2010, 07:57 AM
1255 kbps a decent speed?
is 4015.22 kbps a good speed on my android
one seniors speed test
speed test one seniors
speedtest oneseniors com.au
speedtest oneseniors,com,au
speedtest.oneseniors.com.au
