Battery Percentage?
This is a discussion on Battery Percentage? within the Nexus One Application Discussion forums, part of the Nexus One category; Hey guys, Wondering if there's an app or anything I can download to show exact battery percentage on the top task bar. If not, maybe ...
Results 1 to 10 of 19
Thread: Battery Percentage?
    Member damien8's Avatar
    Battery Percentage?
    Hey guys,
    Wondering if there's an app or anything I can download to show exact battery percentage on the top task bar. If not, maybe an app or widget that will show this on the home screen?
    It's the one thing I'm missing coming from the iPhone.
    Thanks
    Metro Atlanta
    54 times
    I use Battery Indicator from the Market. Works great for me!
    cxm
    cxm is offline
    Senior Member cxm's Avatar
    I have the status bar hidden by launcher pro so I use battery widget on the home screen
    Junior Member jerry_nexusone's Avatar
    viz battery is one of the better ones i've found, hth
    Member raccord's Avatar
    i use batterylife, its a widget.
    Senior Member eZdoesit's Avatar
    viz battery here as well
    Senior Member Gwhiz2k's Avatar
    Can't remember exactly what I use, because I don't have my N1 at the moment (in for repairs), but I think it was "Battery Time", and it puts a nice percentage indicator in the notification bar.
    Nexus One: "Hold it any way you want to!"
    Member ninjacat's Avatar
    battery life. tells you the temp and voltage and percentage and you can customize your battery level colors. But its a widget.
    iphoneeee killaaaaaaaaaa :nexusx:
    Member Krew's Avatar
    Thanks a lot for that suggestion App!
    Metro Atlanta
    54 times
    Glad to help!
android battery percent widget
android battery voltage per cent
android phone battery life indicator missing from home screen
google nexus one battery percentage
how to see battery percentage on the nexus one
how to showbattary percentage on kindle fire hd taskebar
s4 percentage battery task bar
show battery percentage on android task
