Handcent problem
This is a discussion on Handcent problem within the Nexus One Application Discussion forums, part of the Nexus One category; I used to get a chirp in my bluetooth when I was on a call and got a text, but now I don't get any ...
Thread: Handcent problem
    Senior Member Macklessdaddy's Avatar
    Handcent problem
    I used to get a chirp in my bluetooth when I was on a call and got a text, but now I don't get any beep or anything anymore even after having the box checked.i even uninstalled and reinstalled and still nothing.Any help will be really appreciated.
    Maybe you ran out of chirps?
    Senior Member dragongunner's Avatar
    Super Noob question. I recently rooted (one step method) my phone and its working great. Before the root I installed Handcent and it worked perfectly and it still does but now both the stock messaging service notifies me as well as Handcent and it's driving me crazy. I have looked into the settings and can't for the life of me figure out how to disable the stock messaging service so I don't get both notifications. This never happened before the root. Any help would be very appreciated.
    14 times
    Quote Originally Posted by dragongunner View Post
    you need to go into the options of the stock messenger and uncheck the notifications box
    [PHONE] Nexus 4
    [ROM] CM11 Nightlies
    [TABLET] Nexus 7
    you need to go into the options of the stock messenger and uncheck the notifications box[/QUOTE]
    Thanks SliceBurgSlim.
    14 times
    No problemo
    [PHONE] Nexus 4
    [TABLET] Nexus 7
