Battery checking
This is a discussion on Battery checking within the Nexus One Application Discussion forums, part of the Nexus One category; hi. I would like to ask is there any app can check which widget or app (running backgrond) are using how much battery? My battery ...
Thread: Battery checking
    Senior Member wingod_nexusone's Avatar
    Battery checking
    hi. I would like to ask is there any app can check which widget or app (running backgrond) are using how much battery? My battery is just so bad, google repairing centre already replacing me with a new one. I have 3G on 24/7 and auto brightness on.
    Please join Dropbox here: Register :nexusx:
    14 times
    You could always go into your Settings/About Phone/Battery Use Menu and that will tell you in real time what has been using your battery.
    [PHONE] Nexus 4
    [ROM] CM11 Nightlies
    [TABLET] Nexus 7
    Junior Member ArthurIhde's Avatar
    dont need app to do that
    Well, Display always shows 50-80%. Tried restart but seems not much decrease. I believe display include widgets, no?
charles schwab schwab one checking
