Problem with android agenda widget
This is a discussion on Problem with android agenda widget within the Nexus One Application Discussion forums, part of the Nexus One category; was working ok, then i noticed wasnt in sync with my gtasks....couldnt fix it si i decided to uninstall and try something different....problem now is ...
Thread: Problem with android agenda widget
    Member king244's Avatar
    was working ok, then i noticed wasnt in sync with my gtasks....couldnt fix it si i decided to uninstall and try something different....problem now is on one of my home screens where the widget used to be is a box that says'problem loading widget"
    if it matters i am running launcher
    any solutions?
    thanks
    Did you try selecting the box and dragging it into the trash?
    hahahahahahahahahah
    what a bonehead....i guess it was too easy.......
    thanks a bunch.....
    on another note, any idea why i dont get email notifications of replies to my posts, even though i do have that selected.....?
how to fix problem loading widget
htc thunderbolt agenda problems
nexus 7 problem loading widget
