"phone storage space getting low" help me?thnx
This is a discussion on "phone storage space getting low" help me?thnx within the Nexus One Application Discussion forums, part of the Nexus One category; Inspite of that my cellphone's(nexus one) programs is downloaded from market and i is installed on my memory card(sd),my cellphone alarms: "phone storage space getting ...
Thread: "phone storage space getting low" help me?thnx
    Member alexy_alex's Avatar
    Inspite of that my cellphone's(nexus one) programs is downloaded from market and i is installed on my memory card(sd),my cellphone alarms: "phone storage space getting low".Why???
    Android Lurker iPeck's Avatar
    Laval, Qc
    Cuz even if you install to sd, some data must stay on the phone for accessibility purpose.. if you root your phone you can then install all apps to sd even those that cannot be move to sd...
    Cheers
    Android Lurker Lionsson's Avatar
    You don't need to root to force apps to the SDcard.
    Here is a guide, how to force apps to the SDcard.
    Laval, Qc
    Lol its easier and faster to root with one click apps then to use your method but thanks for the info
    It's all about choice my friend.
    Laval, Qc
    android is all about choice, you should have said. :P
    cheers mate
android ally low on space
google nexus one phone storage space is getting low
google nexus phone is low on space
lg thrive low on space
lg thrive storage low?
low phone storage on nexus one
phone storage space is getting low lg thrive
storage space getting low on nexxus 1
surviving low storage on nexus one
