is there a power ap?
This is a discussion on is there a power ap? within the Nexus One Application Discussion forums, part of the Nexus One category; I have a nexus 1 on the way from google.on my old tmobile g1 I used a power ap that helped save my battery.do they ...
Thread: is there a power ap?
    Member bmf5150's Avatar
    I have a nexus 1 on the way from google.on my old tmobile g1 I used a power ap that helped save my battery.do they have it for the nexus 1?
    Its a widget
    What's the difference between a widget and an app?do you download widgets?thanks for the help!!!
    Senior Member geckocavemen's Avatar
    From what I can tell widgets seem to have more functionality on home pages. Instead of just being an icon you can click on to open an app, widgets can let you see things and make changes right on the home page without having to open the widget itself.
    ah cool,thanks!!
  1. Garminfone that much better then Google Maps?
    By TMODroids User in forum Unlisted Android Phones
    Last Post: 06-25-2010, 12:11 AM
