Best battery checker?
This is a discussion on Best battery checker? within the Nexus One Application Discussion forums, part of the Nexus One category; Which battery monitoring app do you guys use? I currently use the one (forgot the name) that takes up one widget space and it reports ...
Thread: Best battery checker?
    Member yhbae's Avatar
    I currently use the one (forgot the name) that takes up one widget space and it reports % on the icon. Pretty happy with it.
    What I am looking for is something that either reports % on the status bar at the top as part of the battery icon(ideal) or provide me % without taking up icon spaces on the desktop (yes, I am almost out of desktop space!)
    If I recall, I saw an app a while back that reports % on the notification window. But I can't recall the name of the app.
    So what do you guys use?
    Member mach330's Avatar
    I like "battery left" on my wife's droid.
    Senior Member Fuse's Avatar
    Battery Indicator shows it in your notification bar. I used that exclusively until I started using Home++ and I hide that bar. I still keep it on there, but usually refer to my Mini Info Widget which has battery, disk, and SD space.
    Rooted Nexus One
    Quote Originally Posted by mach330 View Post
    Apparently this one drains battery quite bad according to the users in the Market.
    Quote Originally Posted by yhbae View Post
    good to know.
    Quote Originally Posted by Fuse View Post
    yeah, i like the mini info widget too.
  1. Epic 4G Root Thread
battery check app
battery widget monitor nexus s
best apps for monitoring battery use on nexus 5
best battery check app
best battery checker
best battery checker app for android
best battery monitoring app
nexus 5 battery monitoring app
top battery monitoring apps for android
what is the best app for nexus 4 for battery indicator
