Low sound
This is a discussion on Low sound within the Nexus One Audio / Video forums, part of the Nexus One category; Is it possible to turn the ringtone volume up more? I set it to the highest volume but the sound is too low. I was ...
Thread: Low sound
    Member intenz's Avatar
    Low sound
    Is it possible to turn the ringtone volume up more? I set it to the highest volume but the sound is too low. I was wondering if there was an app that would overwrite/boost up the volume?
    Thanks!
    To The Top
    Junior Member Jeezy34's Avatar
    Yeah im having the same issue. Do you have it set to Vibrate and ring when you receive calls?
    google audacity 1.3 beta version(thats what i used)it lets you cut parts out of songs then raise the decibels,then simply use that as ringtones
    Thanks, i'll definitely check that out!!
    Quote Originally Posted by Jeezy34 View Post
    http://audacity.en.softonic.com/
android sound is too low
android sound low
android sound low ?
google nexus 7 2 sound is too low
google nexus sound too low
grinder android low sound
increase sound nexus 7.2
increase sound of ringtone on google nexus one
nexus 7 audio low
nexus 7 sound is low
nexus 7 sound toolow
nexus audio low
