"Droooiiid" Style Notification Sound for Nexus One
This is a discussion on "Droooiiid" Style Notification Sound for Nexus One within the Nexus One Audio / Video forums, part of the Nexus One category; I have multiple friends that use the Moto Droid and have the notification sound set as that "Drooooiid" robotic sound. Since I'm the only one ...
Results 1 to 10 of 12
Thread: "Droooiiid" Style Notification Sound for Nexus One
    Junior Member webdevmike's Avatar
    I have multiple friends that use the Moto Droid and have the notification sound set as that "Drooooiid" robotic sound. Since I'm the only one with a Nexus One I decided to "represent" and created a quick sound file that is similar to the Droid sound, but simply says "Nexus One".
    I'm sure someone could create a better one, but I wanted to share it nonetheless. If someone can create one that sounds better then please share.
    EDIT: I added a higher pitched "Nexus One" and I also added a "Nexus" without the "one" at the same low pitch by request.
    Attached Files Attached Files
    Hahaha I really love it!
    Froyo 2.2 Stock
    RA-nexus-v1.7.0
    [SIGPIC][/SIGPIC]
    Android Lurker BayRican's Avatar
    The sound is too low other wise I would use all the time. Great work !
    Member Joshhawaii's Avatar
    Good idea. I would like someone to make something similar that just says "Nexus". The sounds a little weird for me, but good job nevertheless. Thanks!
    Junior Member Airflare's Avatar
    Do it with the protoss voice from starcraft
    Senior Member FC1032's Avatar
    I really like these =) I like the normal "nexus one" version the most.
    Good work! But I doubt I'll actually here them when i use them (I can't here my ringtone even with default ringtones)
    What does the droid one sound like?
    Junior Member sventhebit's Avatar
    Very cool, can you make another saying just 'one'..."Ooooooooooonnnnnnne"
    Senior Member f0ul99's Avatar
    Re: "Droooiiid" Style Notification Sound for Nexus One
    It's cool...
    Senior Member judeeg's Avatar
    WOW! Great Job!
    [SIGPIC][/SIGPIC]Google Nexus One Froyo
    Rooted ~ CM 6RC3~ CM6.0 N1~ Nightlies ~
    Was Using~ eViL's NXSense v.1.21.3 - 720p, BT, FM, Hotspots, Kitchen Sink
    Was Using~ MicroMod's 2.12 Desire SuperHybrid
    Was Using~ MicroMod's Gingerbread CM7 Custom ROM v1.2 (DT's-Ap2Ext,Bat%,Themed
    Was Using ~ BlackDroid's Nexus One - UD 3.1.0Rom
    Was Using ~ CM 7 Gingerbread Green or Blue ExtremeMod ROM
    Now ~ CM NIGHTLY'S
    Member Frank_nexusone's Avatar
    I can't down load these on my phone
    Iphone has an app for that.......Nexus does not need apps its already perfect
  2. Must have Android Apps for the Epic
    Last Post: 11-18-2010, 08:18 PM
android 4.4 vega notification sounds
android vega notification sound
robotic notification sound android
vega notification sounds for android
