Custom Ringtones/Alarms
This is a discussion on Custom Ringtones/Alarms within the Nexus One Audio / Video forums, part of the Nexus One category; guys how about sms? how do we set it for sms tone? I want to set mp3 as the sms ringtone......
Results 11 to 20 of 29
Thread: Custom Ringtones/Alarms
    Junior Member SteveAu's Avatar
    Android Lurker m1bxf's Avatar
    To create a ringtone for an SMS:
    1. Start by creating the Media\Audio\Notifications folder on the SD card
    2. Copy your MP3s to this folder
    3. Unmount the SD card and make sure the messaging app isn't running.
    4. Open the messaging app and go Menu > Settings.
    5. Second option from the bottom is Select Ringtone, open that and choose the file you want.
    I've noticed in all apps which access the SD card for tones you have to make sure the app is restarted after copying the files over or it doesn't list them.
    Hope this helps...
    Thank you very much m1bxf!!!
    Junior Member palmy's Avatar
    Quote Originally Posted by m1bxf View Post
    Hope this helps...
    Does that means I have to root the phone to be able to create directories on the sd card? I used Atro and there is no option to create file/directory.
    TIA
    By FARRR the easiest way to make ringtones/notification/alarms is with RINGDROID.
    It is AMAZING. Allows you to precisely cut/edit songs and mp3 files and save them as ringtones and notifications!
    It automatically saves them in the correct spots, and they instantly showed up as ringtones or notifications!!
    @NEONmonstar
    Rooted NexusOne
    Cyanogen CM6 RC1 FROYO
    RA-nexus-v1.7.1-Cyan
    Galaxy S PRO Theme
    Desire Camera
    4 times
    Quote Originally Posted by palmy View Post
    Hope this helps...
    TIA
    In Astro, Press the Menu Key, Press the icon with the Folder that has a "+" on it...
    Quote Originally Posted by Backnblack View Post
    Got it! Didn't notice the NEW word on it. Thanks a lot.
    Now I have a whole bunch of ringtones!
    Junior Member HoleInOne's Avatar
    Quote Originally Posted by tyler.durden View Post
    A couple years ago I dug up a recording of the hotline phone ringer from the "In Like Flint" spy movies made in the 60s. This ring sound was later copied/modified for the Austin Powers movies. It is a series of pseudo touch-tones fired in rapid succession. You can get the original here:
    http://www.rehorst.com/mrehorst/flintphone_a.wav
    You may need to convert to mp3 (I don't know yet- my nexus one is supposed to arrive tomorrow!).
    Enjoy!
    TD
    I love it. Must check it out!
    Junior Member paulcat's Avatar
    Works Great !
    Member gr8gorilla's Avatar
    Cool post, Thanks!
    :nexusx:Proud new owner of Nexus One as of 1/11/10
    Unlocked Rooted
    Amon-RA recovery v1.7.0(Cyanogen Mod Version)
    Cyanogen Mod LATEST! (Beta or Stable)
    Baked In MoDaCo's Kitchen!
    NexTHEME
    Helix Launcher2
    16GB Class 6 MicroSD
    Twitter @Gr8gorilla
  1. Hands-on with the Samsung Epic 4G
    Last Post: 08-14-2010, 01:32 PM
  2. Samsung Epic 4g coming August 11th?
    Last Post: 08-05-2010, 03:09 PM
/www.rehorst.com/mrehorst/flintphone a.wav
changing ringtone google nexus one
custom ringtone on nexus 1
custom ringtones nexus one
customize ringtone nexus
flint ringtone android
how to change ringtone in nexus 4
in like flint ringtone
movie emergency alarm ringtones for android
nexus 7 wallpapers, ringtones, etc...
nexus one add custom ringtone
nexus one custom ringtone
nexus one custom ringtones
ringtones and alarms for androids
ringtones for nexus one phone
