Custom Ringtones/Alarms
This is a discussion on Custom Ringtones/Alarms within the Nexus One Audio / Video forums, part of the Nexus One category; By the way in case some people don't know it, you can use a program like iTunes, or media player and pick the part of ...
Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Custom Ringtones/Alarms
  1. #21
    Member gr8gorilla's Avatar
    By the way in case some people don't know it, you can use a program like iTunes, or media player and pick the part of a song you want for a ring tone, 30 sec clips seem to work best, then you can save that where you want to find it, and use it. You have to save a clip of song, I know that in iTunes you go into song information to do this.
    :nexusx:Proud new owner of Nexus One as of 1/11/10
    Unlocked Rooted
    Amon-RA recovery v1.7.0(Cyanogen Mod Version)
    Cyanogen Mod LATEST! (Beta or Stable)
    Baked In MoDaCo's Kitchen!
    NexTHEME
    Helix Launcher2
    16GB Class 6 MicroSD
    Twitter @Gr8gorilla
  2. #22
    Junior Member saetam's Avatar
    Quote Originally Posted by unix.punkx View Post
    Just as an FYI, if you would like to use custom ringtones etc. Simply Making a /Media/Audio/Ringtones (and Notifications and Alarms) folder type style on the SD, Android will read this and the new files will show up in picking a ringtone, etc.
    Not necessary. All that needs to be done is create folders in the root directory named "ringtones" "alarms" and "notifications". Without the quotes of course and in lower case. At least that's what I have done and works like a champ. You wont be able to see the sound files you put in the folders until you unmount the phone.
  3. #23
    Senior Member ILoveMyNeXus1's Avatar
    any one know how i can get the t-mobile ring tone on my nexus one? its called "t-Jingle"
  4. #24
    Junior Member raid00's Avatar
    I'm using the futuredial suite nexus one edition. FutureDial Suite for Google Nexus One. it's easy and works fine for me. They even have an instructional video that will guide you through.
    [ame=http://www.youtube.com/watch?v=QkBjhROof-Q]YouTube - Google Nexus One - Load Music as Ringers using FutureDial Suite Smartphone Edition Software[/ame]
  5. #25
    Android Lurker iPeck's Avatar
    Laval, Qc
    Quote Originally Posted by zigadabooga View Post
    Oh and just put in your SD card root:
    Media\Audio\Ringtones
    Media\Audio\Notifications
    Media\Audio\Alarms
    exactly what i was looking for. thanks a lot !
    works perfect.
  6. #26
    Junior Member tatoomtl's Avatar
    Media\Audio\Alarms
    works perfect.
    That's what I did, and I can't see the music (MP3) under the Ringtones.
    Do we have to remove and put back the SD card from the phone, or it is going to refresh automaticaly?
  7. #27
    One solution I found, you can place new songs (MP3) anywhere on you SD card.
    On your Nexus one (in the "Music" section), you will see those files. When you select one, you can go in the menu (button on the bottom of your phone) and there is an option "Use as ringtone"... and that's it.
    Note: I used this step because I've tried to create the folders, and place the files in it. But, my phone doesn't see new files/folder when I go in the "ringtone" section.
  8. #28
    Laval, Qc
    when i place my .mp3's in ringtone folder, the song appears in the ringtone default list. Just make sure you have the folders rooted correctly on the phone and make sure your files have the ".mp3" extension.
    maybe just reboot the phone will do. (for me, it appears without reboot. i transfer from imac directly. works like a charm)
  9. #29
    Junior Member Lord Melbury's Avatar
    Media\Audio\Alarms
    Great tip many thanks.
  1. Hands-on with the Samsung Epic 4G
    Last Post: 08-14-2010, 01:32 PM
  2. Samsung Epic 4g coming August 11th?
    Last Post: 08-05-2010, 03:09 PM
/www.rehorst.com/mrehorst/flintphone a.wav
changing ringtone google nexus one
custom ringtone on nexus 1
custom ringtones nexus one
customize ringtone nexus
flint ringtone android
how to change ringtone in nexus 4
in like flint ringtone
movie emergency alarm ringtones for android
nexus 7 wallpapers, ringtones, etc...
nexus one add custom ringtone
nexus one custom ringtone
nexus one custom ringtones
ringtones and alarms for androids
ringtones for nexus one phone
