Best battery saver kernel for CyanogenMod?
This is a discussion on Best battery saver kernel for CyanogenMod? within the Nexus One Development & Hacking forums, part of the Nexus One category; did it.... i was using an AVS kernel and i was having a lot of crashes and some time the phone stop working and stay ...
Results 21 to 30 of 34
Thread: Best battery saver kernel for CyanogenMod?
  1. #21
    Senior Member Budske's Avatar
    did it.... i was using an AVS kernel and i was having a lot of crashes and some time the phone stop working and stay with a still image...
    now lets see how it works
  2. #22
    oh man thats pershoots kernel...i know about that one i thought this was some other amazing kernel that you found lol
  3. #23
    Junior Member n3gKiwi's Avatar
    I've been using this kernel lately and it is awesome. I've had the same experience, easily able to use phone for 2 days.
  4. #24
    FYI, Pershoot updated his kernel yesterday (4-22-2010):
    Kernel 2.6.33.2 ? OC-UV-BTN-AUD-RAM-VFP_FP (1.113GHZ) ? Nexus - Droid Basement
    The main site to stay on top of updates is:
    Droid Basement - Android – Hacks, Mods, Life
    Radio: 20100203_2 (EPE54B)
    Recovery: RA-nexus-v1.7.0 CM Version
    Rom: CyanogenMod v5.0.6
    Kernel: Pershoot's 2.6.33.3 OC/UV/BTN
    /AUD/RAM/VFPv3 (042610)
    OC mgmt: SetCPU 1.51a
    Theme: none right now...
  5. #25
    ok now i got the kernal flashed and the file pushed. where do i change the UV settings? all i see are the OC settings in setcpu.
  6. #26
    14 times
    Quote Originally Posted by supsandroid View Post
    There are no UV settings. It is automatic.
    [PHONE] Nexus 4
    [ROM] CM11 Nightlies
    [TABLET] Nexus 7
  7. #27
    oh ok gotcha. now i uploaded the 5.0.6 rom (radio was working) uploaded the oc kernal and the radio is working fine as well. so i go to flash just the data.img file from the backup i did before doing all this and now my radio does not work.
    any suggestions?
  8. #28
    14 times
    any suggestions?
    I dont understand what you mean by flashed the data.img file. You flashed this after Cyanogen mod? What was the reason for flashing this data.img file?
    [PHONE] Nexus 4
    [TABLET] Nexus 7
  9. #29
    In the past I'd do a nandroid backup and changed Roms or whatever. Well then I just flashed the data.img file from the backup and it would restore the phone back to all the settings that I had it including all my SMS messages. I have never had a problem until now. I guess changing from a non CG rom to 5.0.6 and then flashing the non CG settings didn't agree with the phone.
    Since all I really cared about was my SMS, I just downloaded wavesecure and am using that now. Much easier and there now backuped to a server
    any suggestions?
  10. #30
    14 times
    Oh ok I see. Yes you probably right about that.
    [PHONE] Nexus 4
    [TABLET] Nexus 7
android battery saving kernel
battery saver in cyanogenmod
battery saving kernel cyanogenmod
best battery kernel fir cyanogenmod rom
best battery saver for cyanogen
best cm kernel battery nexus 4
best kernel for cyangenmod 10
best kernel for cyanogenmod 10
best kernel for cyanogenmod 11
best kernel for nexus 4
cm11 fast charge kernel
cyanogenmod 10 kernel battery
cyanogenmod battery saver
rom for battery saver nexus 4
xda nexus 4 rom battery save
