Is SetCPU worth it for battery savings
This is a discussion on Is SetCPU worth it for battery savings within the Nexus One Development & Hacking forums, part of the Nexus One category; A lot of the reviews I've read in the Market are "OMG... my phone is so fast now!!". My guess is they're mostly overclocked Droid ...
Results 1 to 10 of 10
Thread: Is SetCPU worth it for battery savings
    Senior Member rioja's Avatar
    A lot of the reviews I've read in the Market are "OMG... my phone is so fast now!!". My guess is they're mostly overclocked Droid users.
    How is it for extending battery life? Does it really help?
    Senior Member Budske's Avatar
    yeah, it does with the profiles settings..
    u can set it to downclock the cpu to the minimum when it is on sleep/standby and it saves a lot of battery... and if u add an undervolt kernel with or without AVS it helps a lot...
    im testing it with normal use, avs/svs kernel and setcpu, 2g and sometimes 3g/wifi when i need faster connection..
    avs = Auto volting system*
    svs = static volting system*
    *i think
    there is a screenshot of my battery usage w/o the avs kernel showing that ive used the phone for like 19 hrs and the battery was on 50% :P
    Wow thanks! that's what I wanted to know
    I'm going to get it and give it a try.
    Quote Originally Posted by Budske View Post
    *i think
    Someone posted a vid of the guy at droiddog or whatever getting similar results.
    Running 1.13g under certain circumstances, but down to 3xxmhz when the screen times out etc... Showed him have about 40% after 13hours of phone use.
    Nexus One and luvin it
    Rooted 5/6/2010
    Enomther 2.10.1 Froyo Release
    Junior Member X-Ravin's Avatar
    I've just started using it with a fairly mild tuning and I'm seeing significant battery live gains with no noticeable performance difference.
    My battery life has almost tripled! Performance is the same, so no ill effects there.
    A nice, simple mod. I like it!
    is setcpu an app?
    Quote Originally Posted by tonybhoy View Post
    is setcpu an app?
    yes, it's in the Market. You need to be rooted to use it.
    Quote Originally Posted by rioja View Post
    is setcpu an app?
    i am mate,i will check it out
    You can get it for free if you're a XDA member:
    SetCPU for Root Users [1.5.1a] 04/02/2010 - xda-developers
    you'll just have to update it yourself...
is setcpu worth it
setcpu review
setcpu worth it
