Possible fix for 3G issues (Root Required)
This is a discussion on Possible fix for 3G issues (Root Required) within the Nexus One Development & Hacking forums, part of the Nexus One category; I haven't had any problems with my 3G reception but I came across this while Lurking around on the Cyanogenmod Forum and thought it might ...
Thread: Possible fix for 3G issues (Root Required)
    14 times
    I haven't had any problems with my 3G reception but I came across this while Lurking around on the Cyanogenmod Forum and thought it might be helpful.
    Reverting/modifying Hxpsa 5.0.6 Changes? - CyanogenMod Forum
    [PHONE] Nexus 4
    [ROM] CM11 Nightlies
    [TABLET] Nexus 7
    Senior Member Budske's Avatar
    so... with that i can turn it off?? so it just only use umts???
    cos im having issues that it losses connection on H and it wont connect until i open another program that uses the network and connect again
    14 times
    Quote Originally Posted by Budske View Post
    If all you are looking to do is turn off 3G it can be disabled in your Mobile Network settings. Just check the box that says "use only 2G network"
    [PHONE] Nexus 4
    [TABLET] Nexus 7
    no, just HDSPA...
    i have problem cos when i use 3g the phone connect with 3G, then it change to H and then it start to load the site.
    i was thinking for only using 3G umts no hdspa cos if i dont load any website or something when it is connected it changes to 3g again and it wont go to H until i open another app that uses the network .. i want to leave it on H and edge/gsm or umts 3G and edge/gsm
    14 times
    I'm not sure if the fix in the OP will help with that.
    [PHONE] Nexus 4
    [TABLET] Nexus 7
    Senior Member disbj4ke's Avatar
    Try opening the dialer and enter *#*#4636#*#*, go to phone info. Scroll down to Set preferred network type and change it there. Hope it works for ya.
    CyanogenMod 6.0.0
    Part Monster, Part Machine, ALL ANDROID
'use only 2g network always check fix
3g fix tab root
3g net problem rooted
cm11 2g 3g fix
cm11 3g fix
fix 2g/3g rom cm11 samsung
fix 3g connection root
fix 3g on cm11
fix 3g root application
fix 3g with root
how to fix 3g problem using root
root 3g problem fix
root fix 3g
root fix for 3g
rooted phone 3g network fix
