Need help fixing phone
This is a discussion on Need help fixing phone within the Nexus One Development & Hacking forums, part of the Nexus One category; so i had the desire rom on my nexus one then i did a factory data reset and the phone is stuck on the start ...
Results 1 to 10 of 12
Thread: Need help fixing phone
    Junior Member camist's Avatar
    so i had the desire rom on my nexus one then i did a factory data reset and the phone is stuck on the start up screen. my trackball button doesnt work . does anybody know how to manually go into the phone and put the stock rom back on. oh and i can get into recovery mode but the button doesnt work on the track ball so im stuck
    Senior Member ardynine's Avatar
    pretty sure you supposed to use the volume buttons on the recovery mode, not the trackball. also try removing and reinstalling the battery.
    Re: Need help fixing phone
    ya i know that but in recovery mode i need to use the track ball
    anyone?
    Senior Member Sophia's Avatar
    What recovery program do you use?
    My sigs keep getting
    Senior Member disbj4ke's Avatar
    Quote Originally Posted by camist View Post
    anyone?
    confused about how it says "Sent from my Nexus One using Tapatalk".
    you might want to try and reflash whatever recovery you are using. If you want to go back to the stock ROM then, use the NANDROID back-up you made before flashing Desire (if you did one), or you can Google Nexus One stock ROM download or the Froyo ROM. I think the stock ROM for T-Mobile is ERE27.
    CyanogenMod 6.0.0
    Part Monster, Part Machine, ALL ANDROID
    its the clockwork recovery. and i also have another nexus. i would do that but my track ball doesnt work so i cant select anything once im in recovery mode
    Senior Member rioja's Avatar
    If you can't use recovery because of the trackball, you must get into the bootloader. Unfortunately, you need the trackball for that too. :\
    Have you tried getting into the bootloader by holding down the trackball and pressing power to turn the phone on? If you can get to the bootloader you can flash an update.zip from the command line with fastboot.
    Alternatively, if the phone is currently recognized by your computer, you can issue "adb reboot bootloader" from the command line. I'm assuming you have the Android SDK installed on your computer since your already rooted.
    how do i do that?
    how do i do that?
    Is your phone in the bootloader now? If so, you need download fastboot. You can get it here.
    For Mac: http://dl.dropbox.com/u/585624/fastboot-mac.zip
    For Windows: http://dl.dropbox.com/u/585624/fastboot.exe
    Place it in the "Tools" directory of your Android SDK install. If you don;t have the SDK yet, get it here Android SDK | Android Developers and install it first.
